r you sure that you dont have a down pipe? make sure you dont, you could be havng wat is called boost creep, r you sure it doesnt do it in third gear too, i believe thats where you run the higest boost. i personally would invest in the cobb accessport, it will tell you the codes, i dont know wat that code is, but myguess the guy might have have performance parts on it before. the reason the car could run like crap at higher rpms could be because your leaning out.
LinkBack URL
About LinkBacks
