Results 1 to 5 of 5
This is a discussion on Cabin Air Filter within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; If you spend as much time in your car as I do (about 35K/year) you might really want to check ...
    Nov 2005
    The Holy Commonwealth of Pennsylvania
    Cabin Air Filter
    If you spend as much time in your car as I do (about 35K/year) you might really want to check out your cabin air filter. All sorts of nastiness gunks up in there.
    Check it:
    Yuck.
    It only takes about 5 mins to change and it might get rid of that farty smell in your funky car.
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Wow you got mileage out of that one . Been about 18k since I changed mine, but SD_GR had a recipe for a cheaper DIY Heppa variety, with easy scenting. I have yet to try it, but that was my intent.
    Anyone know the dimensions of the Heppa filter to buy from Walmart to cut to fit?
    Out of curiosity mbs627, what are the dimensions of that filter if you dont mind measuring.
    Nov 2005
    8.5cm x 11cm
    Moderator   Sasquatch's Avatar
    Apr 2004
    Southeastern PA
    Yikes!
    Reminds me ... I need to order one from Tristan. I change once a year.
    Moderator for: Aftermarket Vendor & Installer Review / Detailing Forum / Engine Modifications / Exterior & Appearance
    New Member Hangout / Off Topic / Tri-State
    Mods & Pics
    Jun 2006
    Nor Cal
    Quote Originally Posted by mbs627 View Post
    8.5cm x 11cm
