fuel starvation even in a straight line
Results 1 to 15 of 28
This is a discussion on fuel starvation even in a straight line within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hello subaru gurus, I'm having fuel starvation issues since the install of my Walbro fuel pump . When my gas ...
    Mar 2007
    Hello subaru gurus,
    I'm having fuel starvation issues since the install of my Walbro fuel pump . When my gas tank is anything BELOW 3/4 FULL, it runs into fuel starvation issues when I'm 3/4-WOT. Usually, this appears right at the 5200rpm mark. Btw, when I have the issue, it's not even in the middle of a turn. Pure straight away!
    Your help is greatly appreciated.
    I'm currently running a accessport upgrade map from PDX
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Sounds like fuel filter. Or a loose line on the pump.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Mar 2007
    Quote Originally Posted by 06wrx4me View Post
    do you mean the fuel strainer at the end of the pump or the filter under the hood (silver tin thing)?
    I"m currently using the stock fuel strainer already. It's helped but still far from good.
    Everything on the fuel pump is really snug and tight. I thought that might be hte problem too but i check over it already..
    Jun 2006
    Nor Cal
    Quote Originally Posted by justinklam View Post
    I meant the filter under the hood (silver tin thing). When was the last time it was changed?
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Mar 2007
    i got my 48k service done just recently. And the car was running fine after the service before i did all my mods (injectors, turbo, fuel pump)
    Moderator Donkey's Avatar
    Da boonies,Va
    Was the pump new or used?Have you checked for any leaking fuel?Pull the backseat and check the connections on top of the pump cover as well.See if any are wet.
    2002 FORESTER S
    1998 FORESTER S
    Jun 2006
    Nor Cal
    Did they replace the fuel filter at 48k? Are your injectors leaking?
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Administrator
    May 2003
    What mods and engine management are you using?
    Mar 2007
    Yes the pump is brand spankin' new. I have pulled the rear seats off and the cap where the fuel pump is. it is dry and all conenctions are nice and tight.
    Mar 2007
    I got new o rings before installing. Those cost an arm and a leg but I went all out cause i iddn't want to run into these issues so no, i don't think they are leaking.
    Mar 2007
    Quote Originally Posted by Trainrex View Post
    04 wrx
    Pdx accessport map upgrade EM
    vf35 turbo
    sti pink injectors
    sti tmic
    walbro fuel pump
    catless up/dp (helix)
    greddy evo 2 cbe
    Jun 2006
    Nor Cal
    Has your fuel filter ever been changed?
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Mar 2007
    yes they did replace the fuel filter under the hood
    May 2007
    behind the wheel
    Ok, without trying to sound smartastic..
    are you sure its a fuel starvation?
    What's it doing, exactly? boost levels higher than before, with the new mods? Change the plug gap? At 5200 RPM, does it under WOT? What about 3/4 throttle, low boost?
    checked your fuel pressure? what is it idle? what about idle, with the vac. line disco'd?
    Rogan o_0
    Mar 2007
    I don't have a fuel pressure gauge so i couldn't really tell you.
    What does the car do, it builds boost and pulls and once it gets to a certain part on the revrange, it stops pulling momentarily (like a second), repulls, and backfires. It will keep doing this continuously like pow pow pow until i lay off the accelerator. This happens when the throttle is at anywehre MORE than 3/4 pinned.
    boost levels are lower than before. They are still using the same spark plugs however those will be changed very soon.
