I was getting the same thing
Bad news for me: my turbo's done
it leaks, and could have a crack
Check your turbo?
Time for me to "bolt on" a 38G turbo![]()
This is a discussion on help only hitting 6.5psi within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I need some help peeps. Im only hitting 6.5psi at wot in 3rd and 4th gear. Ive already replaced the ...
I need some help peeps. Im only hitting 6.5psi at wot in 3rd and 4th gear. Ive already replaced the vacuum lines on the t-fitting and the restrictor pill. I've got a boost solenoid on the way also. Is there anything else that could be causing this? Any advise on what else to check?
VF39'd and Clark Tuned
BugEyeMafia #176
Basshead Member #3
Check your turbo?
Hawk Eye #1991
Dirty Crew #11
Military Militia #1991
I still don't know how I got this car...
i hope thats not the case..not ready for a new one yet![]()
BugEyeMafia #176
Basshead Member #3
The car runs great other than only getting half the boost i should be
BugEyeMafia #176
Basshead Member #3
Did you check your wastgate arm? could be that. happend to me i was onlyu hitting like 10 psi. looked around and found ot it was that. replaced it now hitting 17.5 good luck figuring it out.
GrimmSpeed
where can you get just a wastegate arm??? Sorry for all the questions but what was wrong with yours that you saw to know to replace it?
BugEyeMafia #176
Basshead Member #3
Several things.
1. I see you are Cobb stage 1. They have an HWG map for the 02 that may help. You can always call them for tech help too, they are great.
2. Your WG actuator arm may need to be adjusted, fairly common. (yes it has threads and is adjustable)
3. You have a boost leak somewhere. Take your car to a shop and have it smoke tested.
4. Your turbo could be fried, or your catted UP plugged, or your catted UP came apart and destroyed the turbo.
5. Your boost gauge isn't working right.
Hawk-Eye Alliance #001
The Tranny Fluid Thread | HAWK EYEs | 06 Clutch change | 06 timing belt | DIY wooden wheel stands | DIY Alignment
06 WRX TR
talked to cobb and they said that HWG is for bigger than stock turbos.
im getting a catless uppipe next week so that woudl take care of a clogged problem. No boost gauge just using the AP.
for adjusting the wg actuator arm i cant see much of it the heatsheild is in the way. which way would i turn the nut? Should the bcs make a clicking sound when the car is in test mode?
BugEyeMafia #176
Basshead Member #3
the car runs great other than only getting half the boost i shoudl be.
thanks again for the help i appreciate it
BugEyeMafia #176
Basshead Member #3
woot woot problem solved it was the BCS. put a new one in and it works like a champ. Thanks to everyone for all the suggestions
BugEyeMafia #176
Basshead Member #3
Glad you got it figured dude. I didn't think it was a clog.
he used a stock one
06 WRX VF39ED
Wingl3ss @lliance #20
Hawk-Eye Alliance #128
