strong vibes
Results 1 to 3 of 3
This is a discussion on strong vibes within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I thought I was just going across bad sections of highway but now its for sure. I've got strong vibrations ...
    jdd
    jdd is offline
    Apr 2008
    strong vibes
    I thought I was just going across bad sections of highway but now its for sure. I've got strong vibrations coming from the drive train I think. It feels like I have a flat tire. It happens at all speeds and dies off once you stop accelerating. Could it be the drive shaft, differential or in the wheels. Tires are relatively new, differential has no leaks and drive shaft is tight when you try to shake it. I spent a lot of time pulling on tires to check for bearings out and tracing everything underneath and there are no signs of anything. Wheels are random after market but have been fine until now. Please help I am inches away from doing something drastic.
    98 impreza, 2.2, awd, AT
    Registered User jeffmm06's Avatar
    Sep 2007
    Sacramento, CA
    Check tire pressue and balance...
    2005 WRB WRX "was" STAGE 2
    Apr 2007
    8000' up in Colorado
    Yeah, what Jeff said, start with the obvious. You say you have pretty new tires, so did the problem start when you put them on? It's possible you lost a wheel weight too.
    Has the problem come on slowly over time, or did it start all at once? So it only happens under acceleration? Any other time? Is it worse under hard acceleration? Is it tied to the engine RPM or the MPH?
    Scott
