What oil filter and what oil? FINAL
Page 1 of 4 1234 LastLast
Results 1 to 15 of 55
This is a discussion on What oil filter and what oil? FINAL within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have been searching for days and days and hours upon hours just to find what would be a good ...
    Registered User snowflowmfg's Avatar
    Nov 2007
    Sonora, CA
    I have been searching for days and days and hours upon hours just to find what would be a good oil filter and what oil is good to use.
    This has been ridiculously difficult and every place says something different and there's nothing for sure.
    Subaru says use Castrol Syntec and NOT mobil1.
    Nasioc says Castrol syntec is crap, not even real synthetic.
    everyone says they use mobil1 but subaru said that it voids the warranty on the 07's.
    no for oil filters.
    Everyone says use OEM.
    I can understand that, but Purolater is just a basic filter.
    What other filters are good?
    Everyone says Fram sucks? why?
    can't be any worse than Purolater.
    So I just want a final answer, i'm sick of searching and reading.
    I have a 2007 Stage1 WRX.
    WHAT OIL SHOULD I USE (5w-30 or 20?) I live in the mountains so 5w-20 or 30?
    WHAT OIL FILTER SHOULD I USE?
    Hawk-Eye Alliance #116
    Dirty Crew #27
    It's not that complicated. Look in the manual and at the 06+ oil TSB and find the oil viscosity and specifications listed. Buy any oil you like that meets those requirements. If you buy the Subaru filter and it fails, Subaru may pay the bill (I say "may" since you've modified the car). If you buy a filter from anyone else, even the supplier to Subaru but not Subaru directly, and the filter fails, Subaru won't pay the bill. That's really all it boils down to.
    Moderator
    Jul 2003
    Maryland
    Having spent HOURS researching this topic I am comfortable using a OEM filter (why not subaru likes them) and any name brand oil that fills the warranty requirements. Maintain proper intervals and check the oil level at every fill up. You basically CANT go wrong doing this.
    This leaves the option to test several different brands in your driving conditions. If you are overly paranoid have samples sent out to Blacklab Corp. and get them tested. Find which one works best with your motor and just stick with it.
    Once you are out of the "warranty" for the motor then I'd still use OEM filters (why not..they dont cost any more then a good filter from another company) and any name brand oil. If you want to run Syn. oil you can as long as it fit's Subaru's requirements. There is NOTHING that I've seen that says you should not use Syn. oils in Subaru's (for any year). The only oil TSB that I've seen indicated that oil change intervals should be at 3,xxx for all TURBO motors instead of the 7k "idea conditions" interval that the owners manual states.
    Some people have had consumption issues with Mobile 1 in the lower weights....it's not going to burn off in a few start ups...that is why you have to monitor it. If you do notice some consumption with whatever you pick as long as you monitor it odds are nothing is going to go wrong other then you might be 5-10 dollars in the hole per oil change for having to "top off" the oil.
    Nov 2007
    Sonora, CA
    Ok, I know that.
    I just want a straight up answer from someone. what oil? and what filter (assuming OEM is not available)?
    Dirty Crew #27
    Moderator
    Jul 2003
    Maryland
    Quote Originally Posted by snowflowmfg View Post
    Ok, I know that.
    There isnt a straight answer....there is no one perfect oil that fixes everything and will run better then every other oil....that's why everyone keeps saying the same thing.
    Why is OEM filter not available? Buy them in bulk if a dealership isnt near by..you'll probaly save money anyway.
    You are looking for an answer that doesnt exist.
    Nov 2007
    Sonora, CA
    Quote Originally Posted by 302@12psi View Post
    That's what I was afraid of. Being that i'm horribly indesicive, I was hoping that someone would say use this or that.
    Oh well, Subara recently said Castrol Syntec 5w-something was the way to go, I guess i'll use that.
    ...and I guess I will be buying bulk as well. no dealers around here
    Dirty Crew #27
    I have not heard Subaru endorse a product by name. They typically require certain specifications. As long as you use something that meets those specificatios (and they vary by year) then you're set.
    Nov 2007
    Sonora, CA
    I have the thread bookmarked on here.
    It's some kinda update Subaru released about oil and the 07's.
    It didn't endorse anything but it had a short list of oils that met it's standards, and Castrol syntec was on there, so was mobil1 but the weight I need for my area didn't meet standards. Castrol did.
    Dirty Crew #27
    OK good, I've seen that thread also, it makes sense. Honestly, don't worry too much. Just get something with the correct specs and keep up the maintenance schedule correctly and you ought to be fine. I'm out of warranty but still keep all my receipts in a binder (from 2002 -- everything dated and with notes on what the mileage was at the time).
    Nov 2007
    Sonora, CA
    I hate indesiciveness
    Well i'm glad it's finally settled.
    I guess what really riled me a bit was that I just read a thread on Nasioc that linked to a article about how Castrol Syntec was proven to not really be synthetic...but it was a bunch of stupid reading and just worried me a bit.
    I'm gonna hit up subarusenuineparts and get some filters.
    thanks for the help, I need to organize my papers to.
    Dirty Crew #27
    It's a long story but the summary is that all versions of Syntec available in the US are synthetic in terms of legal marketing practices, but most versions of Syntec available in the US are not synthetic in terms of chemistry. In the end, it only matters to me because there is no price break between the true synthetics and the marketing US legal synthetics, but someone that did not know all this already would have no way of knowing by product performance alone -- all of them work as intended. The issue has now become semantic in the US. It's an interesting story but at the end of the day, if the bottle lists the correct specifications for our application you can use the product regardless of source or synthesis pathway.
    Nov 2007
    Sonora, CA
    Exactly.
    Plus, the only thing that set Castrol out of being chemically synthetic was their addition of a super-synthesized mineral oil, which they claimed to increase the quality and performance of their oil and they claimed it to be superior to Mobil1. Then mobil1 probably through a pissy fit.
    If it works, then it's good.
    Dirty Crew #27
    Feb 2008
    Denver
    I'm currently using mobil1 and OEM filter, no issues. Was thinking about going a different route. Might try amsoil, only heard good things about it.
    04 Blobeye wagon
    AFE Filter, ebay catback.
    03 RR Evo sold
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Sticky at top of forum.
    Oil TSB for 2006+ Subarus
    I use nothing but OEM filters. There are a ton of studies showing the differences between them and compares them cut open. Being a design engineer, and knowing how much thought goes into oil supply, filtration, design requirements etc, I'll stick with OEM. That way there isn't any doubt.
    If you like extensive research, there are tons of oil filter comparos where they cut them open and compare and measure media, I've read them and made my own conclusions.
    The OEM filter is $9 with a brand new crush washer from the dealer. The crush washer should be replaced every oil change. Why? CAUSE ITS A CRUSH WASHER! Another bonus, the o-ring on the stock filter comes prelubed!
    A crappy fram filter is $6.99, add in the $1.25 for the crush washer and where are you at? Saving $.75? No thanks.
    Oil. I used to use just regular dino 5w30 SM Energy Conserving change out every 3 k miles. I started to notice pretty bad oil breakdown (same as I had in my previous FI car) so I switched to M1 5w30 SM Energy Conserving. Works great, no breakdown, maintenance intervals now at 3k-5k miles.
    CN:
    OEM FILTER AND CRUSH WASHER
    M1 5w30 SM ENergy Conserving
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Apr 2004
    Southeastern PA
    OEM are best - see for yourself: http://www.bescaredracing.com/sti/oil/filters/
    Mods & Pics
