I've only used Mobil 1 oil and filters on all of my cars for years now. It started when I bought a Porsche 911 in 2001. Porsche only uses Mobil 1 in their cars from the factory and the recommended oil change interval is 20,000 miles on the latest 911 models, and it was 15,000 miles on the last series before that. That should tell you pretty well that Mobil 1 is what you want to use.
I also use Mobil 1 filters because they are more effective than anything else on the market. They remove 99% of particulates, while other filters get 98% at best, and the factory filters as well as some other cheap brands get I believe more like 95%.
I have noted some burnoff of oil, but that's pretty standard in any high HP car that you drive hard. You may need to add a quart every few thousand miles. I change the oil in my STi at about 8k miles and top it off in between. I would let it go longer, but since there's only 5 quarts of oil in the engine, I like to do it a little sooner rather than later. My 911 had a 10 quart oil capacity and no turbo so it didn't burn oil nearly as fast, and it had more oil overall to make sure things were adequately lubricated.
So to summarize:
Buy 5 quarts of Mobil 1 5w-30 - Ignore the "extended life" stuff, all Mobil 1 is extended life. It's just a marketing ploy!
Buy a Mobil 1 filter - Your car uses the M-108 model I believe.
Change your oil every 8-10 miles.
Add a quart every 3k miles between oil changes.
LinkBack URL
About LinkBacks
