Oil Burning Smell On My Wrx, Please Help!!!
Results 1 to 8 of 8
This is a discussion on Oil Burning Smell On My Wrx, Please Help!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I can smell buring oil through the inside car fan after driving my WRX, I cant seem to see any ...
    Jan 2008
    Exclamation Oil Burning Smell On My Wrx, Please Help!!!
    I can smell buring oil through the inside car fan after driving my WRX, I cant seem to see any sort of oil leaks ANY WEAR so cant see wear oil is burning, sometimes after a longer drive in bright light can see some smoke from engine bay AREA and this smell again..
    Any 1 got any ideas as what this could be?? the car runs fine apart from this smell and slight smoke from engine bay area ocasioanlly.
    Thanks in advance
    Apr 2008
    5spd? Slipping the clutch a little too much?
    Jan 2008
    Re-
    yep its a 5spd, but nope it doesnt smell like clutch burn, pretty sure it smells like oil burning..
    Registered User jeffmm06's Avatar
    Sep 2007
    Sacramento, CA
    Oil level down? Check connections at the turbo, IC, look around for stains.
    2005 WRB WRX "was" STAGE 2
    Jan 2008
    Re-
    Hi, the car had an oil service just last month so im pretty sure the oil is still there as therz no leaks and i have checked at the oil filter aswell tht luks fine, i will check the other bits u mentioned.
    thanks mate
    Sep 2007
    Sacramento, CA
    If you do not drive it often, then that explains it. If you drive it often, the oil should have burned off with the first week of driving it.
    Jan 2008
    Re-
    yeh i was thinking that at first aswell, but then lol i realised the day after i had the service i actuali drove it 400 miles within 2days so shudnt be that, and i didnt notice ne smells then, its just started recenlty...but i have used it failry regular since the service, will leave at most say 3days standing then use it again, so it just must be something else!!!
    i have noticed though if i drive it harder its a lil more smokey around engine bay upon checkin afterwards and can smell the oil burin more...
    Registered User WhatThaFrig's Avatar
    Aug 2005
    Knoxville,TN
    Check the PCV valve. I had the same problem.
    "Give a man a gun and he is a hero. Give a man two and he is a god!"
