Results 1 to 2 of 2
This is a discussion on trannys-a-drainin within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; my tranny fluid is draining right now as we speak...my question is how long should i let it drain?....also is ...
    Registered User Dhbamby's Avatar
    Jan 2008
    Lanc Lanc PA
    trannys-a-drainin
    my tranny fluid is draining right now as we speak...my question is how long should i let it drain?....also is there anyway i can speed up the process? i.e. lifting one side/tilting one side
    MY Mods...
    2004 WRX OPB....58k...open source tuned...VF 39 Turbo...Pink 565cc injectors...Walbro FP... Godspeed FMIC...Turbo XS Stealthback Exhaust...Gimmik Turbo Inlet...Gimmik Rad. Hoses...COBB SF Intake...EXedy Lightweight Flywheel...F1 Racing Stage 2 Clutch...Perrin Crank Pulley...Perrin Afta-MAF Hose...HKS Up Pipe...Kartboy Short Shifter and Bushings....lots-o-suspention...
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    I let mine drain for around 30 min last time. Question: Did you heat it up first by driving? If not you may be there a while.
    Also a tip: When adding the fluid, dump in 3 qts drive it around the block very slowly then come back and check it. Wrx trannys have a way of "finding fluid" and you don't want to overfill the tranny.
