Alpine Head unit flickering in WRX??? is this a common problem!!
Results 1 to 3 of 3
This is a discussion on Alpine Head unit flickering in WRX??? is this a common problem!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have just fitted an alpine headunit into my 1994 WRX, however when i turn the volume up to around ...
    Jan 2008
    Exclamation Alpine Head unit flickering in WRX??? is this a common problem!!
    I have just fitted an alpine headunit into my 1994 WRX, however when i turn the volume up to around 20 the headunit starts to flicker, and if turned up higher it even switches off completly then comes back on, i havent got any amp/sub intalled just vibe 6 x 9s.
    does any 1 have ne ideas as wot this cud be??
    i woz thinking some sort of power supply problem, as the headunit runs fine in my other car, but just cant work out what it could be???
    Any ideas appreciated.. thanks
    Thanks in advance
    Registered User adizzle02's Avatar
    Mar 2008
    Sandy Utah
    Quote Originally Posted by az_e11 View Post
    Thanks in advance
    i would check the ground. Usually its that when it flickers. Where you able to just buy a harness and click it together or did it have to be hard wired(each wire connected by solder or crimp connection)
    VF39'd and Clark Tuned
    BugEyeMafia #176
    Basshead Member #3
    Jan 2008
    RE - Headunit Flcikering
    Hi, thanks for your reply, yep the headunit is old and its plugs have been cut off so no harness plugs, so I had to hard wire it myself, im going to check the ground wire as im hoping this is the problem, might just be loose or something
