What 3 gauges should I get?
Results 1 to 6 of 6
This is a discussion on What 3 gauges should I get? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I'm getting a dash gauge pod and need to fill the 3 holes. I'm getting a Vac/Boost gauge and will ...
    Mar 2005
    Holly, MI
    a Vac/Boost gauge and will probally get the EGT. For the 3rd should I get Oil temp or Oil pressure.
    Or should I get something other than EGT.
    I would like to know what most of you have, and what are the more inportant things to monitor.
    Thanks,
    Matt
    Jun 2007
    Great Salt City of Utah
    I would go like your saying and do the oil pressure as your third.
    Registered User efmd3's Avatar
    Jun 2006
    the ham
    water temperature is a crucial one as well.
    the factory water temp doesn't give you an actual temp.
    May 2007
    Delaware
    You should definitely due your research before asking these questions, EGT is a must if you plan on modding, and boost,. Its up to you. A/F is a goodone.
    You should check out this thread.
    Good first mods
    Mar 2005
    Holly, MI
    I have a TBE, and will be getting a new turbo. The above thread only says that EGT and boost are a must. I have really already decided on those 2, but would like to know some opions as to what the 3rd gauge should be.
    As I recall, EGT is an indicator for running rich or lean. Is this coreect.
    What are the benefits on monitoring oil temp and oil pressure.
    05' Saabaru
    Jun 2006
    the ham
    Quote Originally Posted by mucky View Post
    not entirely, but yes.
