97 won't start, won't crank but starter spins...
Results 1 to 6 of 6
This is a discussion on 97 won't start, won't crank but starter spins... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; We replaced the starter and it was OK for a couple of times. Now when I go to start it, ...
    Feb 2007
    We replaced the starter and it was OK for a couple of times. Now when I go to start it, the starter spins but the engine does not..
    Defective starter out of the box? Its a brand new f-ing expensive Denso unit..
    Almost sounds like its not kicking out and catching the flywheel.. I tried turning the engine by hand several times with no luck... Its my friends and its now stuck at my place.. Any help would be most appreciated.
    Oct 2005
    Late Devonian
    Yup, bad starter. I went through a bunch of reconditioned ones once, but would be pissed if it was new.
    Apr 2007
    8000' up in Colorado
    Are you sure you installed it correctly? Maybe something wasn't tightened and after a few drives, the teeth on the starter aren't aligned correctly with the engine? Is it possible the battery doesn't have enough juice?
    Scott
    Feb 2007
    Well, i didn't install it and yup, I fully charged the battery.. all I still get is the starter gear spinning but no engagement..
    And to think I told my friend to go with the more expensive Denso unit for better quality... Sheesh..
    Apr 2007
    Could be that the starter is just bad then. But I'd make sure it's aligned property and that somebody didn't forget to tighten something so that i has shifted since it was installed.
    Scott
    Feb 2007
    well, we found out the problem and yep the starter was bad BUT not for the reason you might think.
    Turns out the idiot mechanic installed a MANUAL transmission starter and my friends car is an AUTOMATIC. Sheesh what a maroon!! it burnt out a new starter which including labor was 339.00
    I bought him a rebuilt starter from my trusty parts place, installed in 20 minutes and it cost him...
    $89.00
    taking the starter back to the moron that put it in and getting his money back..
    next time he WILL listen to me and allow me to do the work/ diagnosis for him in the first place!
