excessive jumping when throttle engages?
Results 1 to 3 of 3
This is a discussion on excessive jumping when throttle engages? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i have an '02 WRX that is all stock with 158k miles on it. when i am in traffic at ...
    May 2006
    Utah
    i have an '02 WRX that is all stock with 158k miles on it. when i am in traffic at speeds under 30 mph it seems to jump excessively right when i engage the throttle and a little bit when the throttle is released to coast. it happens mostly in 1st gear at midrange rpm's so around 10 - 15 mph. is this normal? if not, what might i need to check and/or fix?
    Search clutch recall.
    Check the throttle cabling and mechanism.
    Registered User wrx0131's Avatar
    Jul 2007
    Yonkers, NY
    Quote Originally Posted by rycat_3 View Post
    Do you have a blow off valve on your car....because its alot more jerky at low speeds....i had the same problem.....or it could be that you are stepping on the gas too hard when you are going too slow
