compressor will not kick on if the freon is low. Get a can of 132a and a hose with a gage. Hook to low side which should be marked L near the passenger fire wall. Put freon 134a in system until either the compesser kicks on or your low side pressure gets out of speck. Look around the forum for the specs. also make sure you have the car running with AC on high. Once the pressure builds the compesser will kick on. If it kicks on you most likely have a leak. Check AC hoses for oil , most likely it is a stuck Evac valve. this part is up under the dash passenger side. Look around forums there is a fix for that as well. good luck. only try to fix if you are willing to have a pro correct what you fix!! Enjoy
LinkBack URL
About LinkBacks
