Air conditioning problem -- Help? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
This is a discussion on Air conditioning problem -- Help? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Yes, I've concluded much the same. I'm going to be on the lookout for a compressor in the meantime but ...
    Yes, I've concluded much the same. I'm going to be on the lookout for a compressor in the meantime but am not in a hurry at this point. Thanks!
    Follow up:
    I purchased two new belts from the dealer and replaced both the A/C and alternator belt. Takes around 25 minutes or so, very easy to do. I also carefully aligned the freewheel pulley for the A/C belt tensioner, making sure the bolt is seated flat on the pulley face as I tightened it.
    Noise is now reduced dramatically! No chirps or squeals. I do get a whirring sound when the clutch engages the compressor but am even less worried about it now than I was initially -- thanks everyone!
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    glad it was cheap and easy. cheers.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
  6. #19
    Thanks again. I chose the Impreza to drive into the Mojave yesterday afternoon, celebrating it's re-gained A/C performance (while going to dinner in Las Vegas). Car worked great.
    I need to look closely at the belts in all my cars. I've learned that a belt that theoretically "looks fine" may slip even slightly enough to at least accelerate its own wear.
  7. #20
    Mar 2008
    Glad I found this thread.
    Does anyone know where to get just the compressor clutch without having to buy a whole new compressor ($560+ from the dealer)? Everything runs fine on my AC, the clutch just doesn't engage.
    TIA
  8. #21
    Sep 2006
    Quote Originally Posted by BugeyeMafia170 View Post
    TIA
    well..check to see if you have the correct high and low pressure in your lines, if there is not enough pressure the clutch won't engage anyway
    it's going to be cheaper to just buy the new compressor in the long run anyway.
  9. #22
    Moderator beastcivic's Avatar
    Mar 2002
    Charlotte, NC (USA)
    My '02 had the chirping sound before too. Then it got worse, more screeching. Turned out the belt just had become old and stretched out enough that the initial engagement of the AC compressor was enough drag to make the belt make noise for a split second until the speed of the pulley and the belt were matched.
    I'd guess if everything else seems to work properly, you just need to tighten the belt a little bit. Or buy a new belt, old one might be stretched out beyond tolerance.
    -Jim
    '02 Platinum Silver WRX sedan w/roof rack...bone stock. Ok, now that's a lie.
    GO HOKIES!!!!!!!!!
  10. #23
    I'm afraid I've looked as well, when I initially suspected my clutch was failing -- no luck either. The cheapest route is to buy a few used compressors from wrecks (one at a time) and find one that works. Figure $100. Or, take the clutch out of an ex-tUnEd-now-cRaShEd car and keep the rest of the compressor body as a spare.
  11. #24
    Nov 2008
    I once had a similar chirp, just after AC turned on, cured with belt tensioning.
    I noticed a lot of red "deposit" on your picture. Mine has that too and is currently experiencing some serious whining issues. Anyone know what that's from?
    Don't mean to try to hijack your thread, but maybe its clutch related or something...?
  12. #25
    Nov 2008
    Thumbs up air conditioning
    Ya its correct your guess is right its clutch related sound in buildingregister air conditioning
  13. #26
    Nov 2008
    air conditioning and building security services
    buildingspam
  14. #27
    May 2009
    AC clutch won`t kick on
    TIA
    Save your money and check this out before you spend too much $$$...............>
    My AC clutch would not turn on either, and at first I thought it was the clutch also, but I went with a hunch and decided to check if the refrigerant was low and it was so I recharged it ($20 myself) and Wa laaa! the clutch kicked back on within seconds. My Rex is a `03, and six years is enough time to be low on refrigerant naturally without a leak, no problems since.
  15. #28
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Ray... Welcome to the forums. This topic you just posted in is from December, and I believe (since it's 6 months old) that this issue has been resolved.
    Feel free to introduce yourself in the "New Members" section!
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  16. #29
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by suzemiss View Post
    ****** specialises in the installation and service of commercial air conditioning systems for all types of earthmoving and mining equipment, bus/coaches and trucks.
    SuzeMiss:
    Thanks for your input, but this is considered "SPAM". If you'd like to become a vendor, please follow the "Advertise" links above.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
