Cooling system
Results 1 to 15 of 27
This is a discussion on Cooling system within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi everyone, noticed last night for the 2nd time my temp needle raises into the hot while standing still... and ...
    Registered User tarmacsti's Avatar
    Dec 2007
    South Africa, Jo'burg
    Cooling system
    Hi everyone, noticed last night for the 2nd time my temp needle raises into the hot while standing still... and when I pull off and drive it comes down to the normal operating temp... fan operates as per normal.
    When I got home I checked the reservoir and it was full of water... the car was still hot so I didnít want to open the accumulator res, itís like the water is not circulating?
    So this morning I did the same check and saw that everything was back to normal... could it be that the THERMOSTAT gets stuck?
    **__The Hawk-Eye Alliance__**
    Member #0135
    Nov 2005
    Central Florida
    when is the last time you flushed the system ?
    u might want to burp it
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Dec 2007
    Sounds like a plan Batman! Can you tell me how to do it please?
    thanks!
    Member #0135
    Nov 2005
    Central Florida
    take the upper radiator cap off(the one closest to the turbo) and start the car add water till all of the air comes out... also squeeze the radiator hose a few times to help
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Dec 2007
    Dude youre a Life saver, I will try that!
    Member #0135
    Nov 2005
    Central Florida
    Quote Originally Posted by tarmacsti View Post
    thanks i aim to please
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Dec 2007
    Ok here goes;
    1.Before I started the car I opend the radiator res... some buildt up air escaped?
    2.I started the car with the cap off and filled it with some water, it took about 500ml
    3.As the car heated up I gradualy added more water... some bubbles did boil out and like you said by pressing the hose coming from the radiator it let out some more bubbles.
    4.Everything looked fine water wasnt getting really hot so I waited until the fan kicks in... knowing the thermostat will open before the fan kicks in.
    5.Then the water really started to boil out and the fan kicked in soon after.
    6.I shut down the car and placed the cap back on.
    Anything I missed?
    Member #0135
    You may have to repeat the process to get all the air out; time will tell. However, by simply doing all that you've confirmed two crucial things: that the thermostat opens and that the rad fan kicks in.
    How did this all start? Did you flush the coolant recently or what?
    Dec 2007
    Yeah its reasuring...
    Well I poored a bottle of antifreeze in and replaced the stock cap with a hks one. <--- Could any of these be contributing factors?
    Member #0135
    Why were you low on antifreeze? Is there a leak somewhere or? Does the replacement radiator cap have the same pressure rating as the original?
    Feb 2008
    well buddy unfortunately i just blew out my endtanks today.
    On these model years
    usually the temp gauge above normal indicates > 100C
    You may have gotten air in the system if you recently replaced the coolant.
    But if you did not replace the coolant recently, then get a HG check at a radiator place. You may also want to look for coolant leaks(check for the dried stains).
    Also your car is old enough to need a good flush
    It is really hot now in SA
    Dec 2007
    I kept topping it up with the antifreeze, poored the whole bottle in over a 2day spread. The hks cap has 1.1kg rating on it...
    Member #0135
    Dec 2007
    Quote Originally Posted by silver6933 View Post
    I must add, that when I got the car it looked like the radiator was replaced, but its only acting up like 2 months later... could be many things, me driving the car harder or weather changing, call it what you like...
    I cant see any recent stains... there is alot of stains from before I had the car... my guess is the radiator blew and they replaced it cause it looks brand new..
    After doing the "burp" (excuse me) the car seems alot better...?
    Member #0135
    Dec 2007
    Oh and in the interm I have replaced the hks cap with the original one...
    Member #0135
    Dec 2007
    Update,
    I have done the burping of the sytem now a couple of times and notice that the only time the car temp clibs is after I have driven it really hard... if I then open the cap (after it cooled down) it does blow air out and it takes a bit of water like 250ml to bring it to the brim.
    Also I cleaned out the filler tank next to the radiator and noticed that it was filthy, the buildup inside it looked like mud! So I can only imagine what the rest of the system must look like.
    I will be doing a full flush of the system soon, anyone got any tips on doing this?
    sweet!
    Member #0135
