Cooling system - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
This is a discussion on Cooling system within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Looking at the picture. You have the older style radiater header tank(painted black). Some time the paint on the inside ...
    Feb 2008
    You have the older style radiater header tank(painted black). Some time the paint on the inside flakes off and then circulates within the engine and causes weird issues.
    You have the older style radiator. The newer ones have a cap on the radiator itself.
    You really need to get a pressure test done on the system by a radiator shop. They replace the cap on the header with a tool and then pressureize the system and look for leaks.
    Some times the hoses only leak out under high pressure( you may have a pin prick).
    Try the flush first then get a pressure test.
    Car should be cold
    1. Drain out old coolant
    2. Fill coolant via header tank slowly (to prevent air locks) approx fill + 7 l
    3. put rad cap on
    4. turn heater on full hot. run interrior fans
    5. start engine. run engine at +2000 -2500 rpm until rad fans cycle twice
    6. Switch off engine, wait for it to cool
    7. remove cap. turn cap slowly to release pressure(becareful not to burn yourself)
    8. start engine fill header tank
    9 check if top hose is full of water. press it
    10 put rad cap back on. drive it around the block
    11 repeat 6,7,8
    12 it may need a few more bleeds to get all the air out
    Alternate way to get out the air (note you must have already put in the coolant)
    1 remove header tank raditor cap.
    2. run engine at fast idle
    3. slowly fill water in header tank.
    4. massage top radiator hose (as you press it in and release it(the action sucks the water into the radiator)
    5 water will bubble out of the top of the header tank. (burp) do this until all the water stops flowing out.
    Note you must have the heater on to bleed all the air outta the system.
    These old style rads at a pain to get all the air out.
    Registered User tarmacsti's Avatar
    Dec 2007
    South Africa, Jo'burg
    Thanks alot for the info... of all the searching on the net your post has been the most informative!
    (I think the most important piont I kept missing is to have the heater on inside the car.)
    I will try and feed back!
    **__The Hawk-Eye Alliance__**
    Member #0135
    Nov 2005
    Central Florida
    Quote Originally Posted by tarmacsti View Post
    im glad i was no help
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
  6. #19
    Dec 2007
    Quote Originally Posted by rr1911 View Post
    We were on the right track,
    Member #0135
  7. #20
    Nov 2005
    Central Florida
    its all good
    i was j/k
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
  8. #21
    Feb 2008
    Note you may also have
    1. fail ed/ing thermostat
    2. failing water pump
    3. faulty cap
    4. blockage
    5. wrong coolant ratio
    6. buildup on inside of rad(that rad is over 3 years old(they have not been supplied in SA for that long.)
    7. failed top hose
    8. loose OEM clamps.
    9. crack under oem hose clamps.(you might be able to cut the end)
    10. crack on turbo coolant line.
    11. failing clamps on header tank(VERY common)
    12. sweat between top end tank and rad(more common with 1.1bar cap)
    13. faulty water temp sensor(unlikely)
  9. #22
    Dec 2007
    How about the buildup inside that bottle? That stuff could also be causing some sort of problem?
    Like you mentioned in;
    4. blockage
    What if I remove the thermostat and leave it out?
    Member #0135
  10. #23
    Feb 2008
    That will result in a blown head gasket eventually.
    The stuff coming outta the overflow bottle:
    1. is it oily?
    2. or does it look like milkshake?
  11. #24
    Dec 2007
    okay scratch that idea...
    Member #0135
  12. #25
    Registered User 4cyturbowrx's Avatar
    Nov 2003
    philly
    I hope you didnt put regular water in there, you need distaled water
  13. #26
    Jul 2008
    distilled water?
    Why must you use distilled water?
  14. #27
    Feb 2005
    Charleston
    you don't "have" to, but using regular water leaves the risk that the minerals are other items in tap water can degrade the efficiency of the cooling system and/or leave deposits in the cooling system. Distilled water is extremely cheap and is extremely easy / inexpensive insurance.
    2002 SRP wrx mt sedan
    AP v2.0 stg 2
