How to get rid of CEL'S
Results 1 to 15 of 20
This is a discussion on How to get rid of CEL'S within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; im buying an 04 rex...it has a CEL due to the rear o2 censor(because of the TBE)...the question is how ...
    Registered User Dhbamby's Avatar
    Jan 2008
    Lanc Lanc PA
    im buying an 04 rex...it has a CEL due to the rear o2 censor(because of the TBE)...the question is how do i get rid of the CEL????
    MY Mods...
    2004 WRX OPB....58k...open source tuned...VF 39 Turbo...Pink 565cc injectors...Walbro FP... Godspeed FMIC...Turbo XS Stealthback Exhaust...Gimmik Turbo Inlet...Gimmik Rad. Hoses...COBB SF Intake...EXedy Lightweight Flywheel...F1 Racing Stage 2 Clutch...Perrin Crank Pulley...Perrin Afta-MAF Hose...HKS Up Pipe...Kartboy Short Shifter and Bushings....lots-o-suspention...
    Registered User BUGEYED7's Avatar
    Feb 2008
    Doylestown,PA
    you could either buy the cobb accesport or iv hear that if u put two spark plug anti fowlers together they extend your o2 sensor but idk if that is correct
    Oct 2005
    Ocean Grove, NJ
    Quote Originally Posted by BUGEYED7 View Post
    The twin anti fouler approach works because you are basically shrouding the hell out of the sensor, it still see's some air passing by - but not much at all.
    Cobb and Opensource tuning will allow you to disable the DTC check on the O2 sensor.
    Either one will work, but a protune will yield better results. I recommend going to a good shop and having the car tuned. The Cobb AP is $700 new, - most shops charge between 300-400 for a protune with open source. Skip the AP, and have it tuned.
    However, I usually wouldn't buy a car that isn't stock, and I would never buy a car that has a CEL.
    Feb 2008
    Doylestown,PA
    I agree
    Jan 2008
    Lanc Lanc PA
    the CEL is due to the TBE wich isnt hurting anything ...just tripping a sensor...and the car has low miles and mild mild mods....mods that i would plan on doing right after buying the car anyway....so why not buy a car with a 1,300$ TBE already on it???
    MY Mods...
    Apr 2007
    8000' up in Colorado
    Quote Originally Posted by Dhbamby View Post
    Because people that mod these cars tend to fall into a category of younger drivers that treat the cars pretty badly.
    Scott
    Jan 2008
    Lanc Lanc PA
    yeah usually but im buying it from a 31yrold guy that is responcible....hes in B.U.D.S. Navy SEAL training right now....thats why he doesnt need that whip
    MY Mods...
    I'd not buy a whip.
    Oct 2005
    Ocean Grove, NJ
    Responsible enough to drive around with a CEL?
    As far as I know the government doesn't hold it's armed forces members to any sort of mandatory nor suggested auto-mechanical maintenance guidelines.
    Now on the other hand, if you told me he was a mechanic with OCD and paranoid schitzophrenia - then I'd expect his car to be near perfect and sans CEL.
    Would Never, Ever Say Something Bad About an Admin's Mom SonicWagon's Avatar
    Jul 2007
    Santa Cruz New Mexico
    I'd not buy a whip.
    not in to S&M SD?
    "It is at our most challenging times that we must cheat our very hardest" - Eric Theodore Cartman
    Quote Originally Posted by Weasel 555 View Post
    so whose up for been banned?
    I is teh b1ggest douche evarrrr!~
    Jan 2008
    Lanc Lanc PA
    its not like having the CEL on is bad for the car...the o2 sensor is just measuring more air passing by thats all....getting the CEL cleared will not make the air flow back to stock, it will just remove the light....the same amount of air will be passing through........
    MY Mods...
    Oct 2005
    Ocean Grove, NJ
    Kinda thick huh?
    The issue with driving around with the CEL lit is ignorance, literally. With the light on, you will never see the light ever come on. Unless you have a code scanner wired in and are constantly checking to see if any new codes have popped up, you are disabling the intended function of the CEL indicator. How long has he been driving the car around like that?
    Driving with a CEL is generally a bad idea.
    Jan 2008
    Lanc Lanc PA
    5k
    MY Mods...
    Registered User Aspen700's Avatar
    Mar 2006
    New Jersey
    so did you have to code checked or did you just take the guys word for it?
    it sounds to me like the guy just put an exhaust on it and didnt do any research.
    '04 Aspen White WRX
    Quote Originally Posted by SonicWagon View Post
    not in to S&M SD?
    If I were, I imagine I'd still want a reliable car with a full service history using authentic parts from the manufacturer so that I can drive trouble-free to weekly sessions in which I am gagged, bound, and flogged. After all, I'd not want to be late or have car trouble on the way.
