Gasket
Results 1 to 2 of 2
This is a discussion on Gasket within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; im buying a 04 rex....it has a Turbo XS stealthback on it...i took it to a shop to get it ...
    Registered User Dhbamby's Avatar
    Jan 2008
    Lanc Lanc PA
    Gasket
    im buying a 04 rex....it has a Turbo XS stealthback on it...i took it to a shop to get it up on a lift to check things out and the mechanic noticed that one of the gaskets in the mid-pipe wasnt installed(metal on Metal) ....i was wondering if i need to order a gasket set through subaru OEM or from turbo XS
    MY Mods...
    2004 WRX OPB....58k...open source tuned...VF 39 Turbo...Pink 565cc injectors...Walbro FP... Godspeed FMIC...Turbo XS Stealthback Exhaust...Gimmik Turbo Inlet...Gimmik Rad. Hoses...COBB SF Intake...EXedy Lightweight Flywheel...F1 Racing Stage 2 Clutch...Perrin Crank Pulley...Perrin Afta-MAF Hose...HKS Up Pipe...Kartboy Short Shifter and Bushings....lots-o-suspention...
    Registered User Aspen700's Avatar
    Mar 2006
    New Jersey
    if it is just a flat gasket most parts stores should be able to find something that should work for you. find out what size it is and go to a NAPA or something.
    '04 Aspen White WRX
