Check Engine Light - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
This is a discussion on Check Engine Light within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Just using a code reader they have down at the local parts store....
    Registered User GageP's Avatar
    Dec 2007
    California
    Registered User Subiechk's Avatar
    Apr 2007
    Cali
    Quote Originally Posted by Deathrin View Post
    what are you using to chech the error codes?
    my friend bought a code reader like 9 months ago, and it works for his car but it kept saying error and not giving me a code... any ideas for where else to go or what else to do?
    Wingl3ss @lliance #10
    Registered User Deathrin's Avatar
    Sep 2007
    Bloomington, MN
    if you have a cobb AP you can use that to read error codes. Other then that try autozone... and if you can pull it off of there you might be forced to take it to a subaru dealer. if you need to clear the codes disconnect your battery pump the breaks couple times... and reconnect.
    Blobeye Syndicate #614
    Mods: TurboXS TBE, Defi gauges, ACT HD 6-puck clutch and Steetlight fly
    Pro tune from Matt at 555motorsports
    http://555motorsports.net/
  6. #19
    Registered User Destros's Avatar
    Apr 2007
    Springfield, VA.
    You can buy a decent OBDII code reader from almost anywhere for less than $100. Matco, Bluepoint, Snapon, even a Actron are good simple plug and play scanners. You can check readiness monitors with them too. If it's like $30 at autozone or somewhere of that nature it's junk. Change your plugs. Start with that. Very easy and quick, and a good thing to do for a car.
    -created in the ominous shadow of The Great Vassar-
    Blobeye Syndicate #Eleventy-Seven
  7. #20
    Dec 2007
    California
    Did that and found that it is a bad fuel injector.
  8. #21
    Apr 2007
    Cali
    so i got the car to the dealership and they told me that after i hooked up my stereo i plugged in a dealer plug and that was why the light was flashing and why the car was running like crap...
  9. #22
    Quote Originally Posted by Subiechk View Post
    The one under the steering column? That sounds reasonable.
  10. #23
    Apr 2007
    Cali
    ill have to ask my bf if he did that, cuz when the dealer told me he said it pretty rude like tell to not do me the favor of hooking everything me...anyways it just felt like they were making a stupid excuse for not finding anything wrong....
  11. #24
    Sep 2007
    Bloomington, MN
    Was the check engine light flashing and did it sounds like the fans where cycling on and off like every 5 sec or so?? if that the case sounds like your boyfriend connect the test mode connectors...
    also if you feel you were treated wrong at the dealer and feel it was possible they looked for an easy out you might want to consider talking to the manager... after all you did just give them thousands of your hard earned dollars (assuming you bought it from them)
  12. #25
    Jun 2007
    Great Salt City of Utah
    This is clearly a relationship problem. Dump the boyfriend immediately
  13. #26
    Peachypumpkincheeks
    Speedette's Avatar
    Aug 2005
    Sterling, Virginia
    Now my freakin Check Engine light is on! (Came on, on my way to work this morning).
    Going to check my gas cap, brake fluid, and oil levels at lunch (gotta be precautious!).
    I didn't know Autozone did free code readings. If I can't get ahold of my buddy with a code reader, I'll be going there. Thanks for the info!
    Heather | 2002 WRX | Stage 2
    ScoobyDMCtt | Official Bodyguard #2 for the Bugeye Mafia
    TastesLikeAwesome | @Subiestar
  14. #27
    Sep 2007
    Bloomington, MN
    Quote Originally Posted by Not-EWRX View Post
    haha then post pics and call me
    and speedette I feel you I have had a couple in the past couple weeks just the emission sensor... gas cap... not sure why though it was on tight... think its my new mapps (they standard cobb stage 1 though) Thinking i might just stop buying citgo gas
  15. #28
    Registered User 05wrxftw!'s Avatar
    Apr 2008
    PA
    i threw a code P0546
    exhaust gas temperature sensor circuit high input
