P2443 error code on 2006 WRX TR
Results 1 to 8 of 8
This is a discussion on P2443 error code on 2006 WRX TR within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I had a tech at Autozone pull the code from my 2006 WRX. The check engine light came on and ...
    Feb 2008
    Omaha, Nebraska
    I had a tech at Autozone pull the code from my 2006 WRX. The check engine light came on and the cruise light was flashing. He pulled the following code:
    P2443
    The description of the code was: Section Air injector system switching valve stuck closed bank 2.
    Does anyone know what this means?
    I called a local dealership and he told me the codes may not actually tell what the problem is on the car. I asked about how much it would cost to check/fix the problem and he threw out about $200.
    I bought the car new in September '05. It has about 49,000 miles. So, that means that warranty work is out of the question.
    Thanks for your help.
    Nov 2007
    Chicago, IL
    Sounds emissions related, so engine related. And if it is, you should still be under the 6-year 60k mile warranty, if I understand correctly?
    2007 OBP WRX TR
    Modless till summer
    Quote Originally Posted by dystrbd View Post
    P2443
    Any mods to the car?
    Did the dealer employee not actually tell you what the code means?
    No it doesn't. CEL codes can be emission related. Your state may have specific requirements for manufacturers to support emission equipment. Find out.
    Feb 2008
    Omaha, Nebraska
    No mods
    I don't have any mods on the car.
    From Nebraska. Not sure on the emission laws for the state. You know, all this clean air around here.
    The dealer was not much help. Stated that the code and description that was pulled may not actually be what's wrong. And that they may find more than that. He was very reluctant to quote me a price.
    Thanks for the help. I think I'll try a different dealer.
    Apr 2004
    Southeastern PA
    Greetings and welcome to the club!
    Ah yep. The affected part(s) might have a longer warranty.
    Moving this thread to General Maintenance, Troubleshooting & Tutorials.
    Mods & Pics
    Registered User Aspen700's Avatar
    Mar 2006
    New Jersey
    a lot of people tend to believe that each touble code is a set problem with a set fix that is X amount of dollars. POXYZ = $423 PO123 = $75. a touble code just shows you where to look for the problem. the dealer or any other shop is going to want to see it and check it out before they give you a price.
    '04 Aspen White WRX
    Mar 2009
    P2443
    This trouble code appears when 2 consecutive faults on start up occur in one of the two Secondary Air Combination (SAC) Valves. The WRX has 2 SAC Valves, your code points to the Left Hand (LH) valve. This could be a failed valve or an electrical problem. I recommend you check for a blown 10amp fuse in that curcuit. The fusebox is located in the engine compartment, the fuse is labeled. The secondary air system is emissions. This is straight out of the book.
    Mar 2007
    I have the same code. I checked the fuses and they're good. I'm guessing my next move is to check out the valve and it's solonoid. I'm sure it's easy to get to, like under the intercooler on the left side of the engine...right?
