Results 1 to 7 of 7
This is a discussion on WRK problems within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a stock 02 WRX that has been acting odd periodically. Every so often you can hear the belt ...
    Feb 2008
    Texas
    WRK problems
    Every so often you can hear the belt slip/squeak, and above 4k RPM the RPM's fall by 1K and then it grabs and starts to climb again even though my foot doesn't come off the gas.
    I have more of a mustang background and know next to nothing about the subaru. My first guess would be the clutch is beginning to let go and the belt just needs to be tightened, but I'm not real sure. Any help would be greatly appreciated.
    Moderator
    Jul 2003
    Maryland
    Quote Originally Posted by slammed95gt View Post
    If the RPM's are falling it's not a clutch. If it's slipping RPM's should raise under load.
    Feb 2008
    Texas
    It seems like the clutch isnt disengaging all the way..
    Nov 2006
    Grand Island, NE
    Sounds like a slipping clutch to me. It will get worse and you will know for sure. Maybe time to start setting aside some money for a clutch job.
    Jan 2008
    Decatur, IL
    I'm having the same problem with my 02 wrx. When give my car too much throttle, the clutch begins to slip and my RPMs jump a lot. A few seconds later, after the applied torque has decreased, the clutch overcomes the slippage and slowly re-engages. I am replacing my clutch soon. You can find them on ebay for around 300-400 dollars. If you have access to a lift, replacing it shouldn't be that hard. The hardest part is getting the correct tools. Otherwise, having someone else install it can be a huge rip-off.
    Oct 2005
    Late Devonian
    +1 slipping clutch, slipping belt.
    Quote Originally Posted by 302@12psi View Post
    It is common for them to "catch" but really the load is just less so the RPMs fall back to where they should have been.
    Feb 2008
    Texas
    Ive watched it over the last couple of weeks and can only get the problem to present itself under very specific conditions. In 5th gear @60mph and about 2200rpm if you give it gas and let it lug as soon as it hits 3k rpm it jumps all the way up to 4k rpm then falls and begins to climb again...the speedometer continues to climb...and my boost gauge isnt reading as much as it usually does(dont know if its related) but as far as a clutch goes i never have any other problems hills and stop and go traffic etc...
