CEL after installing my exhust system
Results 1 to 11 of 11
This is a discussion on CEL after installing my exhust system within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Can anyone help? I just installed a turboxcess down pipe, cat, midpipe and currently using my stock exhust. I also ...
    Registered User subydude931's Avatar
    Apr 2007
    KY
    Can anyone help? I just installed a turboxcess down pipe, cat, midpipe and currently using my stock exhust. I also have an injen cold air intake. I drove 3 days out of the week since the installation (last weekend). My check engine light came on, and the car felt slightly sluggish. I figure it was the exhust mod I did, conflicting with 02 sensors. Can anyone help to confirm or deny my hunch, and or just tell me I am all jacked up! Thanks!
    Get the CEL code pulled (go to Autozone or something), and then we can help you.
    Resident Tuner @ WTF Tuning
    Apr 2007
    KY
    Thanks for the tip and I will get back to you on the results.
    Quote Originally Posted by subydude931
    More than likely, it's a rear 02 sensor code (which would be caused by the aftermarket exhaust) - if so, this will continue to happen until you block the code from being thrown (which can be done with an AP/tactrix)
    Apr 2007
    KY
    Hey thanks for the suggestion. I have a hunch that it's the sensor. I'll confirm it when I get it checked in a day or two. I'll let you know. What is an AP/tactrix?
    AP = AccessPort - this is Cobb's EM solution
    Tactrix allows you to connect a laptop to your car, which would also allow you to flash your ECU
    Would Never, Ever Say Something Bad About an Admin's Mom SonicWagon's Avatar
    Jul 2007
    Santa Cruz New Mexico
    you need to remove the cat in your uppipe also before you use Acessport or tactrix
    "It is at our most challenging times that we must cheat our very hardest" - Eric Theodore Cartman
    Quote Originally Posted by Weasel 555 View Post
    so whose up for been banned?
    I is teh b1ggest douche evarrrr!~
    Feb 2008
    What???
    No you don't. You can tune your car with an AP or via OpenECU w/ tactrix cable with a catted uppipe just fine.
    I did that (latter) for the 1st year of ownership of my car. Stock uppipe and dp at that time.
    Jul 2007
    Quote Originally Posted by White GDA View Post
    What???
    well he can not run a stage1 map but with a catless downpipe i though he might try and run stage2 map
    Apr 2007
    KY
    Didn't realize the AP was the COBB Access Port. I figured my CEL was caused by the Stock downpipe I removed with the Xcess downpipe I installed. I'll let you guys know what happens. Thanks for the help!
    Apr 2007
    KY
    Tried an old honda tuner trick, disconnected the battery and reconnected it. CEL is off. Does it come back on? I'll post it, when it does.
