Shattered Piston
Results 1 to 8 of 8
This is a discussion on Shattered Piston within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So I recently shattered a piston and a rod. I was wondering if I got a short block would that ...
    Dec 2006
    Reno Nevada
    Shattered Piston
    I was wondering if I got a short block would that fix it? Or do I need new heads as well.
    Also does anyone know where I could get a used one?
    Thanks in advance BTW.
    May 2007
    behind the wheel
    what caused the "shattered piston and rod"?
    Have you taken the motor apart yet? What's the heads/valves look like? damaged?
    You'll need new oil pump, may as well do a water pump, t-belt, new oil cooler, get your turbo CHRA cleaned extremely well, etc..
    Rogan o_0
    Dec 2006
    Reno Nevada
    I'm assuming that it was an overboost problem.
    My guy hasn't taken apart the heads yet I think.
    Oh I forgot current mods:
    2005 wrx
    VF34+support mods
    Intake, turbo-back
    AP V2
    Thanks again.
    Dec 2006
    Reno Nevada
    Bump for service please!!
    This is largely empirical as Rogan's response indicates. What you need depends on what condition the heads are in at this point. If a show-stopper event sent shrapnel all over it's hard to say what parts were affected without looking.
    I've seen a motor with a shattered piston just a block and oil pump, but sometimes the luck runs out. I'd imagine each case is different.
    May 2007
    behind the wheel
    Quote Originally Posted by Nocturne190 View Post
    why bump it? there's nothing really to say, is there?
    car-part.com for a used motor.
    Rogan o_0
    May 2007
    behind the wheel
    nice use of the word
    Rogan o_0
    Thank you.
