Results 1 to 10 of 10
This is a discussion on can someone help me please within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; can eney one hellp me my 2007 wrx ceeps jumping when i put my foot down it fells like its ...
    obi
    obi is offline
    Feb 2008
    milton keynes
    can eney one hellp me my 2007 wrx ceeps jumping when i put my foot down it fells like its not getting fuel throw the mods if done is (full decat from the tubo back,panal filter,dump vale) some one said its because of the decat on the down pipe
    obi
    obi is offline
    Feb 2008
    milton keynes
    ok
    what about a uprated fuel pump
    Registered User snowflowmfg's Avatar
    Nov 2007
    Sonora, CA
    simple problem. simiple solution
    You have an 07 WRX. You have a catless TBE set-up. that's already bad. 06-07's need to have at least one cat (even a high flow cat) and second: you're running TBE without engine management. You can maybe get away with this on older models but not an 07!
    Because you don't have either, you're experiencing what is called "boost creep" where your turbo peaks way higher than normal due to increased exhaust flow without EM. THerefore your ECU is gonna throw a CEL and Fuel Cut, making your car jump, and die. No fun.
    solution:
    get EM
    optional: high-flow cat
    oh, and if you don't wanna get something like a CObb AP, or go and get your car open source tuned then there are tunes you can get online from places like romraider.com and some other places to put a tune on your ECU
    Hawk-Eye Alliance #116
    Dirty Crew #27
    obi
    obi is offline
    Feb 2008
    milton keynes
    would a up rated fuel pump and a remap do the trick
    Quote Originally Posted by obi
    No need for FP - get a ECU reflash ASAP
    Cobb AP is most popular, but XPT maps would be the cheaper option.
    obi
    obi is offline
    Feb 2008
    milton keynes
    do you now how much it coats and where from
    Quote Originally Posted by obi View Post
    http://www.cobbtuning.com/
    http://www.plasmatize.com/xptstore/i...e=products_all
    Oct 2007
    SoCal
    I don't know how you guys could even understand that jibberish in the original post. I'm no grammar police, but jeez.
    obi
    obi is offline
    Feb 2008
    milton keynes
    chears mate i will look at getting one much appreciated
