turbo wastegate question
Results 1 to 3 of 3
This is a discussion on turbo wastegate question within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; well, to start things off, about a month ago, I was pulling on to the highway and when I put ...
    Jan 2008
    well, to start things off, about a month ago, I was pulling on to the highway and when I put my car into third, the engine suddenly died.
    When I had a mechanic work on the car, it was discovered that my turbo wastegate had jammed. I'm not too knowledgeable about turbos, but would that cause the engine to misfire? What could cause it to jam? Is there something to prevent that from happening? The mechanic told me to get a turbo timer, that heat from the turbo caused it, but with a water cooled turbo, that sounds like BS. I think a turbo timer would be a waste of money.
    Also, after getting my car back, I can hear air when I step on the gas, would a K&N drop in do that? Also, after spooling the turbo and letting back on the gas, I can hear pressure being released. I have a 2005 WRX, completely stock, except for the K&N drop-in filter.
    Oct 2005
    Late Devonian
    Quote Originally Posted by WhiteLightsaber View Post
    I don't know what caused it to jam but that is unusual and a timer seems unnecessary still.
    I'm not sure what you mean by misfire, but yes it could cause a number of problems associated with overboosting. Basically there is no way for the exhaust gasses to bypass the turbine so the compressor keeps cranking it up. It sounds like your EM did its job and noticed that the boost was climbing so you hit fuel cut (car died).
    Yes, a filter could affect the amount of intake & turbo noises you are hearing a little bit. Was this added during the repairs or are you just now noticing it? It sounds like you are describing the BPV and normal boost noises.
    Jan 2008
    Thanks for the info
    I figured the sounds from the filter were normal, but couldn't be too sure. When the car hit overboost and died, I tried restarting the car, and it would start, the rpms would spike to ~1k then drop until the car died. I would have to give the car constant gas to keep it from dying. That is when the CEL light came on. After pushing the car home, I read the codes to be: misfire in cylinder 1-4. After cleaning the wastegate and the MAF, the car ran fine again. Just seems really wierd to me.
