STALLING PROBLEM (dealership stumper)
Results 1 to 11 of 11
This is a discussion on STALLING PROBLEM (dealership stumper) within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; When i'm in traffic and i need to move up like half a car length, i let off the clutch ...
    Feb 2008
    When i'm in traffic and i need to move up like half a car length, i let off the clutch like halfway step on the gas a little and while i'm halfway on the clutch push it back in to stop. Once i have the clutch all the way in the idle becomes rough and 50% of the time it stalls. Its a 2002 wrx with 42,000 miles i bought it in december. Within the last 3 weeks i've got 3 dtc's First p1544 (high exhaust temp) p0? (lean fuel on bank 1) and p0303 (#3 cylinder misfire). I have brought it to the subaru dealership twice and they just clear the code and try to reduplicate the problem while there computer hooked up to it, but they come up with nothing. It could be so many things i'm stumped.
    Oct 2005
    Ocean Grove, NJ
    any mods?
    Feb 2008
    short shifter, blowoff valve, pulley's in the front. nothing major
    Oct 2005
    Ocean Grove, NJ
    Quote Originally Posted by RocNuts View Post
    You can read about BOV's in my sig - short version, get the stock BPV or an aftermarket BPV on the car.
    Just the crank pulley? or a Pulley set?
    Registered User wunderboy987's Avatar
    Nov 2007
    nj
    i bet its the bov, i just put the stock bpv on my car and i feel like a pro shifter, the car runs much smoother and dosnt buck or jerk at all. its harder to stall it too. i can start in second gear without stalling, i couldnt do that with the bov.
    Hawk-Eye Alliance #898Military Milita #898
    AP stage 2 93 oct. maddad DP. SPT short ram intake,SPT intake heat shield,HKS carbon fiber catback,boost,MAF,volt gauges,STI springs, pioneer flip screen headunit, polk audio speakers, vortex generator,STI wing,rally armor UR flaps
    Registered User wrxisthebest's Avatar
    Jun 2007
    Angels Camp, CA
    get rid of the bov.. that could be causing some problems!
    SPONSORS for Rally:AMSOIL, Livewire Energy, Six-feet deep clothing, ARS(Aluminum Rapid Shelters), and FatHeads Eyewear.
    Registered User wrx0131's Avatar
    Jul 2007
    Yonkers, NY
    Quote Originally Posted by wunderboy987 View Post
    same here and it feels so much better with the stock bpv and i also had the same 1st gear problem in traffic
    Administrator
    May 2003
    1: Sounds like your front o2 sensor took a poop, or you have a massive vacuum leak. That would explain the running lean and high exhaust temp.
    2: The BOV is most likely causing your stumble.
    GraysonSubaru's Avatar
    May 2005
    Knoxville, TN
    We have a 2004 in here now with a #4 misfire code we are trying to figure out. We replaced the plugs and checked coilpacks. It doesnt stall or anything, just runs really rough and definitely is against wanting must boost.
    I will have to check to see if it has a blowoff valve though since I am not sure. The mods I know it has are an aftermarket intake and a huge downpipe (looks like it might be a 4in variety).
    after replacing the plugs, it ran good for a little while but after a couple days, the CEL came back and it starting running like crap-o-la.
    that is where we are on this one right now.
    Hey, being the forum car ADD guy is better than being the forum OG.
    Well nobody cares what you think, Seth
    Administrator
    May 2003
    Quote Originally Posted by GraysonSubaru View Post
    Is the plug fouling? Wet? Dry? What color is it when removed?
    1: Run a compression test.
    2: Check for coolant loss, and run a hydrocarbon test on the coolant.
    3: Check for injector pulse with a noid light.
    May 2005
    Knoxville, TN
    Quote Originally Posted by Trainrex View Post
    they are running the compression test now. we had an FXT in here with the same code and the tech said some ring in the engine (i dont remember the name) was destroyed so they are testing for all of that stuff now.
