engine oil vanished.
Results 1 to 15 of 16
This is a discussion on engine oil vanished. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; can anyone tell me what is wrong with my '03 wrx. After i change my oil about 1-3 months later ...
    Jan 2008
    mn
    After i change my oil about 1-3 months later check the dipstick
    and was below the "L" almost to the tip. But no "NO OIL" light comes on.
    Yes i parked the car 15-20 minutes before checking.
    the only mod is the catback , but the oil issue happened even before i slap the catback on.
    I drove to work and from work at mostly 30 lows- 75 highs at highways.
    check under the car for leaks but none was found nor any foul smell.
    check for the blue exhaust smoke but nothing either.
    Anyone have a good idea to what happen to those oil?.
    Official ClubWRX arms dealer SOUTHPAW's Avatar
    Feb 2003
    CT
    It's normal. They burn about a quart every 3000 miles... Some cars (M3's for example) are known for burning a lot more before oil changes. But in your case, everything sounds normal. Just add a little between each oil change...
    *1969 Camaro - Kickin' It Old School
    PICS & MODS
    *2005 Corvette C6 - A few APS bolt-ons
    PICS & MODS <- Built by XX Tuning
    *2003 Subaru WRX - 332 AWHP - SOLD
    Registered User ajd111's Avatar
    Jun 2007
    Pittsburgh, PA
    Quote Originally Posted by SOUTHPAW View Post
    +1
    Quote Originally Posted by BrianH View Post
    Careful, I still think she's packin wang.
    Jan 2008
    mn
    My uncle have a '05 STI , I ask him bout it , he said that never happen to his sti . of course he bought it new , now have about 50k on it, mine i bought my wrx used which have 65k now it have bout 72k.
    Is in Love With the Admins Here 20WRX04's Avatar
    Nov 2004
    WNY
    Quote Originally Posted by guy_in_red_wrx View Post
    After i change my oil about 1-3 months later check the dipstick and was below the "L" almost to the tip.
    I highly recommend checking your oil before "1-3 months later" comes around. I check mine weekly, depending on mileage driven. It's very common for turbo charged vehicles to consume oil between oil changes. Your job is to maintain a healthy amount of oil in the engine so your car stays happier longer. Enjoy!
    The first rule of the Faction is...DO NOT TALK ABOUT THE FACTION.
    NY GIANTS
    Hybrid Faction #19
    Blobeye Syndicate #19
    Mods
    Jan 2008
    mn
    i do check weekly, but at times i just lost track.
    but if everyone says is "normal" , than i guess i can put my worries aside for now.
    Moderator Donkey's Avatar
    Da boonies,Va
    Run a thicker oil
    2002 FORESTER S
    1998 FORESTER S
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Try a synthetic motor oil. I live in a hot climate and had issues with dino oil breaking down and being 1/2-1 qt low after 3000 miles. Since I made the switch to Mobil 1 5w30, at 3-5k miles there is 0 fluid loss.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Jan 2008
    mn
    I used to put in synthetic mobil 1 the expensive kind, recently i decide to
    use royal purple synthetics with a mobil 1 oil filter plus lucus lub oil.
    I change even before the 3k miles, but oil keeps runing dry.
    Jun 2006
    Nor Cal
    Are you talking the really thick lucas stuff?
    This stuff?
    http://www.lucasoil.com/products/dis...tid=2&loc=show
    If so thats your problem, that stuff is thicker than glue. Also depending on what year Wrx you have, Royal Purple is not recommended by Subaru, and I know Lucas is not recommended by either Subaru or Royal Purple. You may have been fine with just RP but I think the Lucas killed you.
    Oil TSB for 2006+ Subarus
    I fear with the lucas being so thick you may have damaged the seals in your tubocharger and the oil is "vanishing" in liquid form out your exhaust system through the DP and into the catalytic converter.
    or
    The PCV is spitting it back into the Intake track and your air inlet tube and intercooler are filled with oil.
    You may have opened a whole can-o-worms here.
    My advice to you now, is to do a compression check on your cylinders to help rule out serious engine damage. Compression in each cylinder should be 120psi+.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Registered User vcustoms's Avatar
    Jan 2008
    Northern Jersey
    dude....got the same problem!!!!
    got an 05 wrx and i burn about 1qt every 1k miles.....now i try to stick with royal purple full synthetic.....runs a lot better with less oil consumption.....also u might wanna use an oil catch can....check ur TMIC...i bet u have a light film of oil in the tubes
    Nov 2005
    Central Florida
    i would listen to jermey
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Jul 2005
    Northern Illinois
    I have a 2002 WRX
    Bought new and after my usual break in proceedure I switch to Mobil 1.
    I have close to ZERO oil consumption and I still check regularly.
    At 68k miles car actually runs better now than the first 20k miles.
    I run Mobil 1 in all my vehicles:
    GMC truck
    Wife's Audi
    WRX
    Street warrior corvette.
    As for Lucas additive:
    I wouldn't put ANYTHING Lucas makes in my vehicles.
    Lucas is a marketing company designed to take your money.
    Read this:
    http://www.bobistheoilguy.com/images/lucas/lucas.htm
    WR
    2002 Black WRX
    1998 GMC 1500 Pick up
    *1988 corvette street legal pro-street car
    best time 1/4: 10.5 sec at 129 mph
    *2003 Great Lakes Region Corvette Challenge Drag Racing series Points Champion.
    *2006, 2007, & 2008 NMCA True Street Class winner
    Jan 2008
    mn
    Thanx for the awesome info(s).
    I will stick to just syn oil.
    Apr 2004
    Southeastern PA
    Quote Originally Posted by 20WRX04 View Post
    Quote Originally Posted by 06wrx4me View Post
    Mobil 1 5W-30 since 6600 miles. No discernable amount of oil consumption here.
    Mods & Pics
