| General Maintenance, Troubleshooting & Accidents. What kind of oil should I put in my car for drag racing? When should I change the spark plugs? How do I fix that rattling sound I'm hearing? Ask your maintenence questions here! |
| Advertise On ClubWRX | ||
LinkBack | Thread Tools |
Rating:
Display Modes |
#1 (permalink) | ||
My mom says I'm not fat, I'm "big boned".
>>Tranny Fluid Info and Experimenting Thread<< (Amsoil, Redline, USC, etc.)
UPDATE:
To start off, a link to " MEMBER TESTIMONIALS (on page 2 of this thread)" where there are tons of testimonials and lots to read. What I ended up running and install pics. >>>>HERE on page 4<<<< MY Blackstone analysis of my USC fluid that I replaced. >>>HERE<<< Also started a "What fluid was your car running when it blew?" thread. One more link to the Uncle Scotty's ****tail Thread on Nasioc. With that said where I started at 1-30-08: So it is once again tranny fluid time in my car, or getting close anyways. Last time I used a synthetic version of USC or "Uncle Scottys ****tail" I came up with. It works great, but in my quest to not leave well enough alone and brand homogeneity, I wanna try an all Amsoil formulation. Specifically, replace the Frankenstein colored Redline Lightweight shockproof with something, but we'll see where the research and findings take me. What I am currently running: Quote:
4 0z Amsoil slip lock 1 qt Amsoil MTG 1 qt Amsoil syncromesh 1.5 qt Amsoil 75w90 gear oil. The bold is what I am thinking about to replace the Lightweight shockproof. They have a lower kinematic viscosity at 40 deg which should lead to improved shift at cold temps. Using all Amsoil products also guarantees (through Amsoil) that I can up the service interval considerably. Discuss.
__________________
~ Jeremy ~ 240WHP 290WTQ ![]() MY 06 WRX MOD LIST Hawk-Eye Alliance #001 The Tranny Fluid Thread | HAWK EYEs | Ghost Ride the Subaru Quote:
#2 (permalink) |
Moderator
This is interesting. I don't know much about the demands of a gearbox on lubes, but it seems the wear items will be mainly the syncros and gears themselves (let's leave any other components aside unless someone sees a disaster coming). You should be able to tell how the syncros like it just by shifting.
Assuming you go for it, you'd have no way to know the effect on the gears themselves unless you stuck with it and looked for bits or sent off a sample (I don't know if Blackstone does gear lube analysis). Plus, what's a "normal" sludge after a gear oil change vs. an abnormal sludge due to increased wear? I don't know. Given all that, if you do try it, my advice is to pay attention to shifting and also to whine, and either way I'd actually not listen to Amsoil, I'd keep shorter intervals than they recommend just to be safe. Amsoil are good with questions. Have you considered using whatever product combination they recommend instead of the Uncle's mix with substitutes? BTW, how may miles on the previous full-synth ****tail?
__________________
He who drifts drives slowly. Walter Roehrl Νους υγιής εν σώματι υγιεί. Mod, New Member Hangout, Southwestern region, International, Vendors' Forum |
#3 (permalink) | |
I have not contacted Amsoil, but now that you mention it I think I will, although I fear I will get an android on the phone who replies with only "Use 75w90 Severe Gear." Hopefully i can talk to a lubrication engineer.
I have just over 17k miles on the previous ****tail, and while the "color " seems to be fine, based on "Uncle Scotty's" recommendations and my own OCD habit of shorter maintenance intervals, I'm considering a routine fluid swap. The transmission has loved the old concoction and still shifts more smoothly than stock. My main reasons for wanting to stray from the USC: 1. is for research for Subi members benefit (buying all ingrediants from one MFG is a lot easier, as currently you need to hunt all over town to find them) 2. Possibly further improve on the ****tail. 3. Help dispel the "glass tranny" rumor by making mine live at elevated power levels. 4. Get rid of the dead warranty voiding giveaway of the Frankenstein blue fluid color. 5. Further improve shifting/reduce whine at start up temps over USC. (Redline Lightweight shockproof has a kinematic viscosity similar to 75w140.)
__________________
#4 (permalink) | |
I spoke with a lubrication engineer over at Amsoil after getting the typical drone canned corporate response from the technician. The Engineer was very knowledgeable and helpful. He had concerns about mixing different fluids, even those within their catalog. After explaining the USC ****tail to him and my take on it and its performance, he explained that a 20k-30k mile service interval would be recommended for it maximum. The reason being is that specifically the Syncromesh fluid (5w30) is Engine oil based as are its additives and they conflict with the SVG 75w90 additives and cause them to degrade quicker. After explaining to him the above results I wanted to achieve, we came up with a formulation that he believes will be very effective and its simple.
3 qts MTG 75w 90 gear oil 8 oz Amsoil slip lock The MTG has the same high heat protection as the SVG 75w90, but has less friction additives so requires more slip lock. The MTG is also 30% thinner than the SVG in cold weather despite their similar rating. He also urged I test the USC (have it analyzed) for Science sake. Both Amsoil and Blackstone labs offer testing services for a fee. Amsoil kit/testing fee is $26. Blackstones fee is $22.50. Blackstone it is. Before I swap the fluid I believe I will give Redline a call and see what their take on the situation is.
__________________
#6 (permalink) | ||
Moderator
Quote:
Quote:
I'm heading over to Amsoil's site to look at their verbage. Nice detective work there, great info you've uncovered! EDIT: I see the MTG is listed as GL4 and MT-1. I thought MT-1 was a GL5 that's safe for yellow metals in manual transmissions (hence the MT). I did not know a GL4 could be MT-1. Did he mention whether it's GL5? (I'm assuming he knew you "need" a GL5).
__________________
He who drifts drives slowly. Walter Roehrl Νους υγιής εν σώματι υγιεί. Mod, New Member Hangout, Southwestern region, International, Vendors' Forum Last edited by SD_GR; 01-30-2008 at 03:58 PM. |
#7 (permalink) | ||||
Quote:
Quote:
Quote:
__________________
Last edited by 06wrx4me; 01-30-2008 at 07:56 PM. Reason: A tidy thread is a happy thread. |
#8 (permalink) |
Moderator
OK good to know, I figured the MT-1 had Subarus "covered" in a way.
__________________
#9 (permalink) | ||
Swapover table
Amsoil = Redline = Mobil1 = Valvoline = Royal Purple
MTG 75w90 = 75w90NS SVG 75w90 = 75w90 = LS75w90 = Synpower 75w90 = Max Gear Slip Lock = Limited slip friction modifier I still dunno what Redline Lightweight Shockproof = ? And without fluid property listings similar to amsoil, its hard to find out. It appears from what little literature they have available that it performs slightly better than their 75w90 under normal circumstances but really outperforms it in a shock load situation. * see pdf on redlines website for graph. Edit: on page 2 of the PDF it shows Lightweight shockproof as being GL5 Edit: After extensive web testimonials (Nasioc, Forrester forums, random DSM sites) it appears most people rave about running solely the lightweight shockproof in the Subaru 5MT. The Redline website seems to be rather vague or with holding on applications or crossovers for the Shockproof. I see no OEM or API ratings listed anywhere. Verbage that intrigues me From redlineoil.com: Quote:
__________________
Last edited by 06wrx4me; 01-31-2008 at 03:05 PM. Reason: Added Mobil1 & valvoline |
#10 (permalink) |
so which one are you using right now ?
1 qt Redline lightweight shockproof 1 qt Amsoil syncromesh 2 qt Amsoil 75w90 gear oil. or 4 0z Amsoil slip lock 1 qt Amsoil MTG 1 qt Amsoil syncromesh 1.5 qt Amsoil 75w90 gear oil.
__________________
Army Ranger For Life ! Thin Blue Line Military Militia # 1911/ Blobeye Syndicate # 1911/ Modifier's Anonymous # 1911/ Hawk-Eye Alliance # 1911 All We'll Drive ![]() DIFFERENT STROKES EVEN MY DENTIST TOLD ME FLOSS 7 DAYS A WEEK POST WH0RE KING
#11 (permalink) | |
That one.
__________________
#12 (permalink) |
ok so your using (SVG) and not (MTG)
what are your thoughts on what he recommended...3 qts MTG 75w 90 gear oil + 8 oz Amsoil slip lock ?
__________________
#13 (permalink) | |
Moderator
Quote:
__________________
#14 (permalink) | ||
Quote:
Technically I am currently running a similar mixture with the addition of the Redline Lightweight Shockproof. As listed above, I have found a lot of positive reviews for the redline lightweight shockproof in the 5mt. It will be interesting to see what Redline recommends tomorrow. IMPORTANT NOTE: The STI 6MT has an oil pump inside the transmission for lubrication. Redline strictly recommends against using shockproof in that configuration. So does Uncle Scotty. I also ordered my Blackstone labs kit, so in about a month we'll have some spectro. data on the USC.
__________________
#15 (permalink) | |
Quote:
__________________
| Thread Tools | |
| Display Modes | Rate This Thread |
