This is a discussion on >>Tranny Fluid Info and Experimenting Thread<< (Amsoil, Redline, USC, etc.) within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by 06wrx4me I too agree that syncromesh does not belong in the mix and had suspicions of it ...
I'm also in this camp. I really don't see the syncromesh doing any good in that mix. Much different viscosity than the rest of the parts.
Pavia, I saw your ill fated story half way through your post.Sorry.
I'm also glad you got the Extra-S in there. That should be great fluid for a street driven car.
Part A: well put my Mix of 1.7 Q Redline NS and 2 Q of Lightweight shockproof in at about 39K and I am at almost 57K now.
Still working pretty well and getting close to the 20 K point. Dub you still having success with yours or did you switch out to another fluid?
Next up may try the Amsoil instead of the Redline NS.
How many K on your mix Jeremy?
Part B: This goes for those posting and not wanting to read the thread. Insights from this thread are as follows.
If you want ONE FLUID: Subaru extra S is your oil....either buy a 5 gallon jug at cheap cost or go to NASIOC thread that has it at 20 bucks a quart.
If you want an effective TWO FLUID mix: USE TWO Q Redline LIGHTWEIGHT shockproof.....and EITHER 1.7 Q Redline 75W90 NS OR 1.7 Q Amsoil 75W90 SVG
(Please note I am no specialist or saying use one or the other....all cars and trannys and drivers and locations are different...try it, if you dont like it try another)
Hawk-Eye Alliance #001
The Tranny Fluid Thread | HAWK EYEs | 06 Clutch change | 06 timing belt | DIY wooden wheel stands | DIY Alignment
06 WRX TR
Forgot to mention the status of my drain plug when I swapped the USC out...
Well, nothing major. No chunks like I've seen in other forums. Basically, a small amount of blackish-grey residue on the end of the magnetic plug. I attribute this to a mixture of sludge and fine metal particles. Just enough to cover the tip of your finger...
So that's after 9k on USC. I recall it being similiar on 10k of factory fill.
06 GTO M6 Quicksilver, SLP 455 Bobcat, LS7 Clutch w/ SS line (RPM tune:373rwhp/373rwtq)
07 WRX TR M5 Garnet Red Pearl w/ Straight PPGs and Cusco front LSD (Agile tune:307whp/343wtq)
^ that's what I typically see regardless of fluid![]()
I own a 2003 WRX (stock).
I measured my gear box oil level the other day and found out that is missing some, since I was on a hurry I couldn't get Redline, which was my intention, so I ended up buying Lucas Heavy Duty 80W/90 to fill up my gear box. I haven't added it yet, since I don't use the car very much yet.
Do you guys think it will be okay adding/mixing that Lucas Quart with the oil that the box has currently?
Is not synthetic, however, is heavy duty.
Should I add it or wait and buy Redline's?
Hey Jeremy you working with anyone over at Blackstone with your oil analysis if you're doing it?
My tranny has the lightweight and Redline NS mix in it with just over 20 K on it. I was going to change it out and try the Amsoil SVG mix but wanted to send some of my old fluid mix in for analysis as well as a new mixed up sample of the LW NS mix for comparison.
Might make sense to work together with blackstone and combine all the data.
06 WRX TR
i have ppg straight cut gears and i the oil on my tranny is like real light blue does anybody knows the name of the oil thanks .
lightweight ShockProof (by Redline)- good stuff![]()
