>>Tranny Fluid Info and Experimenting Thread<< (Amsoil, Redline, USC, etc.) - Page 11
Page 11 of 27 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 151 to 165 of 404
This is a discussion on >>Tranny Fluid Info and Experimenting Thread<< (Amsoil, Redline, USC, etc.) within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; so, jeremy.. I decided not to read through countless pages of this thread.. should I go to scottys mix, or ...
  1. #151
    May 2007
    behind the wheel
    so, jeremy.. I decided not to read through countless pages of this thread.. should I go to scottys mix, or something else. I'ma be doing this tomorrow or sunday..
    Rogan o_0
  3. #152
    Apr 2004
    Southeastern PA
    Try the mix in the mods link in me sig.
    Mods & Pics
  4. #153
    May 2007
    behind the wheel
    it doesn't appear that there's anyone 'local' that sells Redline fluids..
    booo
    Rogan o_0
  6. #154
    Registered User Hold_Fast's Avatar
    Mar 2008
    Philly Burbs
    I'm also going to be doing this in the next couple days and was a little confused by the difference between the lightweight and heavy shockproof/if it would be appropriate for my 5MT. I live in PA it can get pretty cold and pretty hot...
    Thanks for the help Jeremy.
    ~Stan
    '04 WRB WRX Wagon (Build) - Hard Parked, AutoX Toy
    '08 WRX ~ Daily Beaten ~ '86 BMW 325es ~ "The Chump"
    "I was raised knowing there is a replacement for displacement, it's called engineering."
  7. #155
    Aug 2002
    Virginia Beach, VA
    No subie should ever run heavyweight shockproof...always lightweight. Heavyweight is like the consistency of cold margarine...
  8. #156
    Jul 2007
    Wilkes-Barre/Scranton/Allentown
    I live in PA and I used lightweight shockproof and it made a big difference.... I would go with Extra S if I had people to split it with or maybe just use it myself...
  9. #157
    Mar 2008
    Philly Burbs
    Quote Originally Posted by Timdog1650 View Post
    Thanks Tim.
    ~Stan
  10. #158
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    ^^^ Exactly. LW shockproof only.
    I still am really happy with the Amsoil SVG and Shockproof mix. Very nice smooth shifting, nice and quiet. Better IMO then Uncle Scottys mix, but I blame that on the "Syncromesh" fluid. Its not compatible with the other two and doesn't belong.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
  11. #159
    May 2007
    behind the wheel
    rear diff like any 'mix', or a standard fluid?
    Rogan o_0
  12. #160
    Jun 2006
    Nor Cal
    no "mix" needs be done in the rear diff, but the R180 requires a special "dealer sold" Subaru diff fluid in a tin 1L can. The r160 you can use pretty much anything in. I have LW Shockproof in my rear diff right now, which seems to be working fine. That little R160 gets such a workout and holds soo little fluid I'd throw synthetic in it though. It only holds ~.8L and at 15k miles my fluid was black, burnt and stinky both times. I can't imagine what its like in cars that are over 60k miles with no rear fluid change.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
  13. #161
    Registered User Pavia's Avatar
    Dec 2006
    Philly/DE area
    Quote Originally Posted by 06wrx4me View Post
    Would you recommend an aftermarket rear diff cover then to increase capacity?
    06 GTO M6 Quicksilver, SLP 455 Bobcat, LS7 Clutch w/ SS line (RPM tune:373rwhp/373rwtq)
    07 WRX TR M5 Garnet Red Pearl w/ Straight PPGs and Cusco front LSD (Agile tune:307whp/343wtq)
  14. #162
    Jun 2006
    Nor Cal
    Quote Originally Posted by Pavia View Post
    More fluid is a good idea, however the cost of the diff cover can often be the same price as a replacement rear end. The Perrin Piece is $250. If you install you are out the price of fluid and maybe a gasket, but if someone else installs you'll be out around another $150 for labor plus fluid and parts.
    Something to think about.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
  15. #163
    Jul 2001
    Plains of Eastern Montana
    do the aftermarket ones increase capacity or are the just designed w/ fins and the like to aid in cooling?
  16. #164
    Registered User xmikex's Avatar
    May 2008
    cali
    whats a straight forward good tranny fluid??
  17. #165
    DUB
    DUB is offline
    Registered User DUB's Avatar
    Jul 2007
    SLT, CA
    Quote Originally Posted by xmikex View Post
    That's what the 163 posts before yours are all about.
