>>>>The I smell raw gas from my WRX and its cold outside Thread (TSB inside)<<<< - Page 9
Page 9 of 11 FirstFirst 1234567891011 LastLast
Results 121 to 135 of 157
This is a discussion on >>>>The I smell raw gas from my WRX and its cold outside Thread (TSB inside)<<<< within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I fixed this issue myself this past winter. It is a pain in the butt for sure....
  1. #121
    Nov 2009
  3. #122
    Jan 2013
    Being fixed on my 02 next week by the local dealer under warranty... 135K miles. Wondering if it has anything to do with recent random misfire CEL.
  4. #123
    Dec 2011
    Pottstown PA
    Quote Originally Posted by yosty View Post
    i dont think so but take it to the dealer and see if they can fix it and tell them about any problems you have
    IF YOU HAVE A MISFIRE CODE ,PLEASE READ THIS!!!
  6. #124
    Registered User bry831's Avatar
    Sep 2013
    Hendersonville, NC
    Ok so what if you have all of these symptoms but it is not cold outside? Then what? I smell raw gas at startup, poor gas mileage, low boost, and dipping idle but only when in gear (not in neutral).
    02 WRX 177,000 miles
    only mod is an invidia up-pipe but the car was doing this well before that install.
    Any ideas? I see no wetness at all under inspection.
    much thanks.
  7. #125
    Sep 2013
    Hendersonville, NC
    Oh and recently threw a p0172 cel.....
  8. #126
    Find and fix the gas leak; treat the PO172 as a PO171 for troubleshooting.
  9. #127
    Now I think of it the car is telling you it's running rich; fix PO172 and see if the smell goes away, you may get lucky.
  10. #128
    Sep 2013
    Hendersonville, NC
    It was bank one so where would I start? Sorry, suby nuby. My only experience is the up pipe so far and that was more just mechanics than diagnosis.
  11. #129
    Quote Originally Posted by bry831 View Post
    There is only 1 bank.
    See:
    Running Rich Bank 1 After Mods..
    Bank 1 Lean ...help
    02 wrx CEL help
    check engine light po171
  12. #130
    Apr 2013
    I just noticed this smell and a small pool of fuel underneath the V in the manifold on the drivers side of the engine bay. Is this something that SOA will pay for because of the TSB (I have a 2004 sti) or are they only doing it for the WRX's?
  13. #131
    Sep 2013
    Hendersonville, NC
    Quote Originally Posted by Errodis View Post
    I am pretty sure they won't honor the TSB anymore. Maybe if you are the original owner but probably not. Won't hurt to call and ask. Regardless SOA sells the fix as a kit that you can purchase at your local Subaru dealer and it is only like $40 or so. The $ is in the time to change it out. You have to remove the entire intake manifold because that part is underneath and attached to it. The part is what delivers fuel to the injectors. You will also get new gaskets in the kit for both sides of the manifold. You will have to remove the intercooler, alternator, ac compressor, etc. and so on. Pretty much anything in the way of the intake mani. If you have a decent amount of experience with your subie or any other car you shouldn't have a problem with this repair. Should take around 4 hours. If you take it to someone to have it fixed it will run you around $450-500.
  14. #132
    Jul 2012
    Just got home from dealer fixing fuel leak on my '02. Free repair under warranty. Washed the car, put on a new radiator hose and fixed my windshield washer too. Can't believe they covered the problem on an 11 year old car! Subaru is alright with me!
  15. #133
    Registered User JordWRX's Avatar
    Dec 2013
    Olympia, Washington
    Subaru will most likely honor it because it is a liability and leaves room for a lawsuit if something potentially happened. I would have your local dealer fix the issue. I know its not a total recall, because a lot of states don't have the required weather conditions for this to take place, which saves Subaru money so they don't have to replace all the fuel line problems for cars that won't need it in warmer climates. My car started to have this problem and I live in Washington, which is not listed for repair of this part. Since I do live east of the mountains for college it gets quite cold and was able to smell gasoline one day when driving around town. Came back on the west side of the mountains for X-mas and went to my local Subaru Dealership in Olympia to get this fixed (since Ellensburg doesn't have one). They said that they will have to message Subaru directly, since it is not as cold and they can't copy the effects of the colder climate that the east side has, otherwise the cost would come out of their pocket.
    In the end I hope Subaru confirms the fix so it doesn't come out of my pocket or me having to drive to Yakima to get it fixed (since it's on the east side of the mountains and the closest to Ellensburg (30 miles away)). Sorry for the rambling.
  16. #134
    Dec 2013
    Olympia, Washington
  17. #135
    Jul 2012
    The warranty ends in 2014 per the dealer who fixed mine so if you need it done, better do it now! It doesn't matter if you are the original owner or not. The warranty is on the car, not you.
