>>>>The I smell raw gas from my WRX and its cold outside Thread (TSB inside)<<<< - Page 7
Page 7 of 11 FirstFirst 1234567891011 LastLast
Results 91 to 105 of 157
This is a discussion on >>>>The I smell raw gas from my WRX and its cold outside Thread (TSB inside)<<<< within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; They should, yes....
  1. #91
    Would Never, Ever Say Something Bad About an Admin's Mom SonicWagon's Avatar
    Jul 2007
    Santa Cruz New Mexico
    They should, yes.
    "It is at our most challenging times that we must cheat our very hardest" - Eric Theodore Cartman
    Quote Originally Posted by Weasel 555 View Post
    so whose up for been banned?
    I is teh b1ggest douche evarrrr!~
  3. #92
    Registered User CerealkillerJST's Avatar
    Nov 2008
    Asheville, NC
    Has anyone attempted this job themselves? Having the manifold off provides opportunities for other job/mods such as TGV deletes, turbo inlet upgrade, and phenolic spacers.
    You can't blame a compass for pointing north.
    '02 Wagon, modestly modded for now.
  4. #93
    Nov 2009
    I am planning to do this soon. I will take lots of pics.
  6. #94
    May 2005
    I just started having this issue last Friday on my 2003 WRX sedan (133K miles). It was super cold (for SoCal anyway) and the raw gas smell was really strong. I thought it might be the fuel filter so i swapped that out but that didn't work and so I was finally able to trace it down to the other side of the car (it was windy earlier and skewed my ability to trace the smell) just below the turbo coolant reservoir. It was just pooling there.
    I took it to the mechanic who was practically just closing for the weekend. He called me today and said that he still hasn't identified the leak because there are so many parts above the area that the leak is that it is taking him forever to get them out.
    Sounds like this is going to get expensive. On the plus side, I found out why I was getting erratic boost. Vacuum line was split at the waste gate and as soon as i touched it it broke into several pieces.
    May be time to upgrade to an STI
  7. #95
    Sep 2010
    British Columbia
    the wvl-22 fuel rail replacemen recall is not a mandatory warranty item for dealerships. as it is a problem only on older bugeye wrx's each dealership has the option of replacing it on good will warranty or not, their choice. so if you can't get the dealership to soak the cost then try another dealer. I replace them free of charge but other dealers may not.
    And a TSB is nothing but a service notification to the technician. TSB does not equal warranty, just a concer.
  8. #96
    Registered User eddie-mondo's Avatar
    Jan 2011
    eastern Idaho
    i just bought an 03 bugeye from a buddy of mine, that was the first thing i noticed when i started it up the day i picked it up. i could smell gas from inside the car. Just wondering if the dealer would still honor the recall seeing how i'm not the original owner?
    i only noticed the smell that one day though. i may have to look into it a bit further to see for sure if it is leaking at all..
    2003 WRX- Newbie
    1997 S-10 zr2- work/quad hauler
    1991 crx si-r- all motor B16
    1989 crx si- beater
    "It looks like Scarface sneezed on you car!"
  9. #97
    Supporting Member yamaha_rider619's Avatar
    Jul 2009
    colorado is home, Kansas is the temporary home
    they should, i got mine done last year, not the original owner either
    Josh
    2003 Subaru Wrx Vf39'd
    Bugeye mafia #300
  10. #98
    Jan 2011
    eastern Idaho
    sweet! i'll have to look into it further for sure...
    2003 WRX- Newbie
    1989 crx si- beater
  11. #99
    Jul 2009
    just call your local dealership, give them your vin, and tell them you want your recall done. simple as that
    Josh
    Bugeye mafia #300
  12. #100
    Registered User Smeee's Avatar
    Aug 2010
    Richmond, Virginia, United States
    Quote Originally Posted by scoobietech View Post
    eh, SOA said otherwise. When I called them they said that the dealer 'HAS TO DO THE SERVICE' and that TSB # gets them paid. just saying.
  13. #101
    Registered User WhiteRabbit80's Avatar
    Nov 2009
    Colorado
    So I have this problem on my '04 WRX. Has anyone had any luck getting the recall payed for on an '04?
    Also I've read through this thread, and haven't been able to determine the threat of fire. I had smoke coming out from underneath the manifold on the passenger side bank today. Kinda freaky.
    Edit: So I just got home and took a look under the hood, and there is a lot of gas there. More than what would be caused from "seeping". I got onto the SOA website and looked under my vin number for recalls, this one wasn't on it. I'll try to get it into the shop soon anyway, because I'm genially afraid of there being a fire, or me passing out at the wheel! I'm freekin High right now! If I had the time I would do it myself, hope the shop doesn't take me for a ride.
    1997 Impreza Brighton
    2004 Impreza WRX
    2002 Honda 919
    Drive it like you stole it!!!
  14. #102
    Feb 2011
    Longview, Alberta, Canada
    I have an 02 that has been getting the smell of fuel on cold days, the CEL has been coming on because of misfire and my gas mileage has not been quite up to par. Is that because of the fuel rail or something else? I replaced plugs for the misfire but it still shows a misfire. I even used dielectric grease on the coils. If it is the fuel rails, what do I need to replace/fix the problem?
  15. #103
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by Maverick Cayce View Post
    How are we supposed to know without any other data? Diagnosing a car over the internet is not as easy as people think. Fix the fuel leak and see if the problem goes away. That would be the common sense thing to do as if the vehicle is leaking fuel that could be a fire hazard.
    There is a TSB that Subaru put out that discribes whats involved in fixing the fuel rail. Also most dealerships are fixing this for free. Please re-read the thread again. You posted in the misfire thread. How many different things were listed that cause misfires? Plugs were only one of those.
    2002 FORESTER S
    1998 FORESTER S
  16. #104
    Feb 2011
    Yeah, I read the other thread. I hadn't started any other checks at the time. I was just seeing if someone may have experienced something similar to the jerking after changing the plugs. Thanks for the list of possible problems on the misfire thread by the way.
  17. #105
    Nov 2009
    I'm trying to get a handle on all of this. I have an 03 wagon with 105,000 miles. I smell the raw gas this winter and am getting worse gas mileage. I bought my wagon used at a large Chevy dealership. There is a local Subaru dealer here in Tulsa (actually Broken Arrow). Are they required to fix this problem, and if they are, what do I even say to them as to where the problem is? Appreciated any help on this.
