Power Steering Pump, Pulley, or Belt?
Results 1 to 9 of 9
This is a discussion on Power Steering Pump, Pulley, or Belt? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So I've been having problems with my power steering on my 2002 USDM Sedan WRX for a couple weeks, especially ...
    Sep 2006
    So I've been having problems with my power steering on my 2002 USDM Sedan WRX for a couple weeks, especially on cold starts. When I turn the wheel from a stop (i.e. to get out of a parking spot) the power steering belt skips and screeches loudly, and the wheels struggle to turn.
    Before the problem got this bad, I used to smell burnt rubber on cold starts. Now I know what it is...
    I've also had occasional trouble starting the car, which leads me to believe that the alternator pulley may be skipping on that same belt.
    I've ordered a replacement belt in hopes that a new belt at the correct tension will fix the problems. However, my concern is that there may be excess resistance (seizing?) on the power steering pulley causing the belt to skip. If so, I'm wondering if I may have to replace the pulley on the power steering pump and/or the pump itself. Any experience here would be appreciated.
    Thanks,
    Mike T
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Only way to tell is too remove belt and spin power steering pump.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Nov 2007
    sounds like power steerum pulleys siezing up a bit, that'd explain the squealing and burnt rubber AND poor steering, the pulley may be coming apart from the fins inside, yank the belt off, and spin the pulley alot, look for dead spots or points where it resists the spin
    Moderator beastcivic's Avatar
    Mar 2002
    Charlotte, NC (USA)
    My vote is the belts are old and loose. I had a similar problem with my car, and ignored it for a while because it was very infrequent. Then one belt broke. I had them replaced by a local shop. They used standard aftermarket replacement parts on it. Those lasted about 10 days before I had the problem again. I had to buy genuine Subaru parts to get the right size belts. Seems like they're slightly undersized, and if you buy aftermarket options, you'll never get them adjusted properly (you'll be at the max extension on the adjusters, and they'll still be loose).
    I thought my pulleys were siezing up, but I was easily able to spin them when the belts were off. Its a cheap attempt to fix it at $10 a belt.
    -Jim
    '02 Platinum Silver WRX sedan w/roof rack...bone stock. Ok, now that's a lie.
    GO HOKIES!!!!!!!!!
    Dec 2010
    l have the same problem what was the out come
    Registered User 4cyturbowrx's Avatar
    Nov 2003
    philly
    I had the same problem. I went through 3 diff belt to I went with a suby belt... But also replaced my tensioner to....
    Aug 2008
    Kennett Square, Pennsylvania
    Quote Originally Posted by jsin93816 View Post
    Check your belt tension and condition first, 1/2 in. of deflection for every foot of free span
    Dec 2010
    ill check the belt and pulley and hope its just the belt
    Moderator Donkey's Avatar
    Da boonies,Va
    Replacing the pulley on the power steering will do nothing to fix the problem is there is resistance as the cause of the resistance would more than likely be the power steering pump itself.
    2002 FORESTER S
    1998 FORESTER S
