Service ramps for '08 wrx?
Results 1 to 9 of 9
This is a discussion on Service ramps for '08 wrx? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi all, I am looking to do my first oil change on my 08 WRX and my current ramps donít ...
    Nov 2007
    Hi all,
    I am looking to do my first oil change on my 08 WRX and my current ramps donít fit, the stock body kit hangs too low in front of the front wheels to drive up these ramps. Does anyone know of any good low profile ramps that will work with a '08 wrx premium?
    TIA
    Registered User Feezor's Avatar
    Nov 2006
    Ca
    Not sure but try putting some 2 by 4's under the tires then use those to drive onto the ramps
    Registered User Pavia's Avatar
    Dec 2006
    Philly/DE area
    I use the Blitz low profile ramps and they just fit with a slightly lowered WRX. I would try the 2x4 with your ramps, or if you can get a jack under the crossmember, raise it and put your ramps under the tires (or jackstands).
    If you can fit, just run the fronts on the 2x4 and you could change the oil from there.
    I feel your pain. I once used my wife's cutting board to get an extra inch with my jack...
    06 GTO M6 Quicksilver, SLP 455 Bobcat, LS7 Clutch w/ SS line (RPM tune:373rwhp/373rwtq)
    07 WRX TR M5 Garnet Red Pearl w/ Straight PPGs and Cusco front LSD (Agile tune:307whp/343wtq)
    Nov 2006
    Ca
    Just was reading a magazine and thought of this thread when I saw this pic of an STI up on ramps here is a website that might help http://raceramps.com/
    Nov 2007
    Thanks all for the suggestions, I will give the blitz a look over and the burte industries. I had considered the 2x4s, but didnt want to deal with trying to come back down my ramps onto the 2x4s and risk them slipping out.
    As far as the jack, I have a failry low profile hydorlic jack, does anyone know where the jack points are on the '08s?
    Registered User ctank77's Avatar
    Dec 2007
    Arlington, VA
    Jack points on 08 WRX?
    Quote Originally Posted by Amnizu View Post
    Anyone jacked up their 2008 and used jack stands? I'd like to know what points you used. Thanks.
    Jul 2001
    Plains of Eastern Montana
    my lowered wagon no longer fits the Blitz ramps- two short 2x4's in front of the tire fix that
    the race ramps are nice, but look at the price
    if I'm going up on jack stands- I use these "mini" ramps so the floor jack clears- not really high enough to change your oil (unless your skinny )
    http://www.discountramps.com/plastic_car_ramps.htm
    Dec 2006
    Philly/DE area
    Quote Originally Posted by ctank77 View Post
    The owners manual should list the points for an '08. On an '07, the jack stand points are just behind the front tires and just in front of the rear ones (there's a lip that runs the length of the under side just beyond the side molding).
    Jack points are the steel crossmember behind the oil pan and the rear diff. I always use a piece of wood between the jack and the car to avoid damage and give a couple inches of extra lift.
    I avoid jacking the car up on just one corner. I've heard of people twisting unibody frames doing this. Maybe an urban legend, but I always jack up an entire side to be safe (front, back, or all of one side)
    I would really like to get a V-lip spoiler for the front to control high speed instability (my car drifts occasionally on windy days at highway speed).
    My biggest concern though is clearance. Even if I get the race ramps or use 2x4's, what happens if I ever have to take it in for, say, an alignment? 19 yr-old service tech scraps it along the lift is my best guess...
    Jul 2001
    I'm lowered ~ 30mm f/r the two different alignment racks I use have posed no problems- that's w/ no lip, lip would definitely add to the difficulty- 2x4 could be used if need be on the alignment rack- I'm fortunate both places I use I'm there the entire time (they have me drive on/off the rack) and help turn wrenches
