02wrx whining/whistling noise from ..alternator?
Results 1 to 15 of 18
This is a discussion on 02wrx whining/whistling noise from ..alternator? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; my wrx started makin this whining / whistling noise... its coming from around the alternator, whether it could be a ...
    Registered User ezzzey's Avatar
    Apr 2006
    my wrx started makin this whining / whistling noise... its coming from around the alternator, whether it could be a belt, the alternator it self or something around that area...
    anyone any idea?
    the higher i rev the louder it is...
    i could make a recording (audio).
    Started happening next day i belive after i did my downpipe reinstall...
    could i have possibly screwed something up? I mean, i've done the dp like 3 times already since i had to change it back to stock for emissions.
    dave
    any input appreciated.
    Registered User jeffmm06's Avatar
    Sep 2007
    Sacramento, CA
    you could take the belt off and spin the alternator by hand, see if it is the beginning stages of seizing up. Probally would be worth your time so it doesnt snap your belt on the road. I'd check that them come back with the results.
    2005 WRB WRX "was" STAGE 2
    Apr 2006
    Quote Originally Posted by jeffmm06 View Post
    so basically check if the alternator spins freely?
    will do that now.
    Registered User WRX13oy's Avatar
    Jul 2003
    SOCAL!! 91752
    check your a/c idler pulley. and dont drive it too much or this will happen
    SOCAL F4#02 OG member
    2002 PSM WRX stage 6
    2007 Kawasaki Ninja ZX6R
    Apr 2006
    Quote Originally Posted by WRX13oy View Post
    a/c idler pulley? would that actually spin faster the higher the rpms? Cause the whining/whistling gets louder w/ higher rpm's.
    Gonna go check alternator and a/c pulley.
    Jul 2003
    SOCAL!! 91752
    ya. it spins faster as the engine rpm goes up.
    before it decided to blow up on me, my car sounded like it had a supercharger on it.
    Apr 2006
    lol thats exactly what mine sounds like lol i like the sound, but i know it aint healthy.
    So it might be my a/c idle pulley seizing up? or... thats why the belt messed up?
    Jul 2003
    SOCAL!! 91752
    the bearing in the pulley seized which caused the belt to melt the pulley. it costs about 25 bucks at the dealer for a replacement pulley, but i just took off the belt and the tensioner for now since its winter time
    Apr 2006
    the belt goes around 3 pulleys, i can just remove the belt?
    And it seems like the sound is coming from the pulley to the right of the alternator above the a/c pulley.. What is that anyway?
    Jul 2003
    SOCAL!! 91752
    you can take off just the belt.
    before i found out what the problem was, i also thought the sound was comming from between the a/c and alternator, but it turns out the the sound was being transfered from the pulley to the bracket to the engine block. the car drives so much better now
    Apr 2006
    the car drives a lot better after removing the belt? why you say that?
    And what is the component to the RIGHT side of the Alternator?
    Jul 2003
    SOCAL!! 91752
    Quote Originally Posted by ezzzey View Post
    it drives better because that pulley was causing a lot of friction and made my car die or almost die all the time when i stop at a light.
    the component to the right of the alternator is the A/C compressor and to the left is the power steering pump.
    one belt powers the alternator and power steering and the other belt powers the A/C.
    Apr 2006
    cool, thanks for the great info, im gonna be taking off my belt after i finish eating, anything ishould know by chance? Seems pretty simple when i looked at it at work.
    Jul 2003
    SOCAL!! 91752
    its not really hard to do. just make sure you loosen the bolt that holds the idler pulley to the bracket before you start cranking on the adjuster bolt. a friend of mine forgot to do that and snapped it
    Apr 2006
    anyway to test how stiff the belt should be for the alternator ? since i had to remove it to remove the a/c belt.
    just made it tight, by eye i guess and feel.
