Results 1 to 4 of 4
This is a discussion on ecu or air intake problems HELP within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; my 02 wrx is not working properly no check engine light, and after 3500RPMs it doesent speed anymore like if ...
    Jul 2007
    bradenton fl.
    my 02 wrx is not working properly no check engine light, and after 3500RPMs it doesent speed anymore like if the engine was empty no power no boooooost nothing i'm going crazzzy plz heeeeeelp
    mods only an air intake. i think is M.A.F.sensor because i changed it with my brother that has the exact seme car and it work but i just purchesed a new sensor and it didnt work so i exchanged it for another one and the same thing help i dont have the stock intake what should i do
    Put the factory intake back on, and mount the MAF sensor so that the harness faces FORWARD. Make sure the O-ring is intact. Does the problem go away?
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Quote Originally Posted by subwrx02 View Post
    put on stock intake.
    MAF installed right?
    Is it in valet mode?
    post pics
    Oct 2002
    The Old Folks Home
    Moving to correct forum.
    Please notice what forum you're in before posting new threads.
    --Ray
    Proud owner of a N.E.R.D.
