Serious Help!!!
Results 1 to 15 of 18
This is a discussion on Serious Help!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I was just driving and a guy ran me off the road. Well everything was ok until i ran through ...
    Registered User littlebro's Avatar
    Nov 2007
    Exclamation Serious Help!!!
    I was just driving and a guy ran me off the road. Well everything was ok until i ran through a puddle. Snow, ice, slush water everything built up on my cai filter. Now car is running ruff and white smoke coming from exhaust. Any body know what could be wrong, and what i need to do to fix it.
    Jun 2007
    Great Salt City of Utah
    At think in the best situation you will need a new turbo. But you might need a new block as well. Water in an engine is no joke.
    Registered User 06ltd's Avatar
    Feb 2007
    NJ
    pull off your air filter, clean it, dry it, and reset your ecu. see what happens.
    Moderator
    Jul 2003
    Maryland
    Quote Originally Posted by 06ltd View Post
    Yup. I'd try not to run the car until all this is done. You might also want to drain your oil and see what you might find in there.
    Nov 2007
    what do i need to do to reset my ecu
    Feb 2007
    NJ
    Quote Originally Posted by 302@12psi View Post
    A good idea, but be sure to drain the first half quart into a clear jar so you can tell if there's anything in there.
    Disconnect the neg. battery cable and depress the brake pedal for 30 seconds or so to reset the ecu. Check to see if all your radio stations reset to make sure you did it correctly.
    Registered User ElBartoRex's Avatar
    Feb 2003
    Chester Co. PA
    Quote Originally Posted by littlebro View Post
    A guy ran you off the road? that doesn't sound shady at all... story please..
    Current: 05 Mini Cooper S R53
    Former: 06 Acura RSX Type-S
    Former: 00 Integra GSR
    Former: 07 Mazdaspeed3
    Former: 04 WRX Stage 2+
    www.jscspeed.com
    Nov 2007
    what would i be needing to look for in my oil?
    Feb 2007
    NJ
    water or, god forbid, coolant.
    Nov 2007
    It was this ass in an audi tt. We were sitting at a light take off not really racing just getting up to speed and he just started swerving at me, and for some reason screaming at me from his car. He continued this until i had no choice but swerve off the road or hit him.
    Nov 2007
    so would i be able to tell fairly easy if either water or coolant is in there.
    Feb 2007
    NJ
    yeah, water will be a blob in the bottom of the jar, or look like small marbles. Coolant will usually be foamy.
    Nov 2007
    k should i check my oil before i reset my ecu. or should i check my ecu see how it runs and if its still doing it then check my oil.
    Registered User jeffmm06's Avatar
    Sep 2007
    Sacramento, CA
    hmm and people wonder why we say do not get a CAI.
    2005 WRB WRX "was" STAGE 2
    Feb 2007
    NJ
    clean your intake and see if the problems go away. If they don't then check the oil. Fact is, you would have had to injest a serious amount of water to actually get it into the engine. What's more likely is you screwed up the maf and o2 sensor and they're sending bad readings to the ecu.
