Results 1 to 14 of 14
This is a discussion on Help on CEL code P1086 - Tumble generator valve within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So my 02 WRX wagon throws out the code P1086. Checked and found it is the: < Tumble generator valve ...
    Registered User black_knight's Avatar
    Mar 2007
    < Tumble generator valve #2 (LH) position sensor circuit low input >
    Does anyone know where it is located and how to fix/replace it. It tried clearing the code but it does not happen.
    Thanks!
    Jan 2008
    houston texas
    Quote Originally Posted by black_knight View Post
    Thanks!
    i have the same cel code, i took it to dealer, they told me i need to replace the whole tgv, the sensor its on top left of your maniflow
    Mar 2007
    Quote Originally Posted by celularhn View Post
    Hey thanks, I did replace just the sensor and it solved the CEL code, thanks for your help!
    Jan 2008
    houston texas
    where did you get the sensor from, im been loking for one, and how much was it
    Mar 2007
    I got mine for 100 bucks..just for the sensor...
    Whcih side do you need and I can check if i have it...PM me with details
    Jan 2008
    houston texas
    i need sensor # 2 wich is the sensor on the driver side
    Mar 2007
    I have the sensor from the pessanger side, don't know if they are interchangable though. The dealer was selling the whole TGV unit for over $300 i think, and did not separately sell the sensors...bummer!!
    If you can find the pessanger side works...then you'll be all set...
    Aug 2009
    code p1086
    hi i own a 2000 subaru wrx and got the same fault now do you think it might just be the sensor how easy is it to find one ,do you have a part number for that .Please help and also is it easy to replace or have to go to a mechanic
    thanks
    Mar 2007
    Quote Originally Posted by rohan View Post
    thanks
    It was easy to replace it myself...I just had to replace the left one...but I still have a right one, but it is for a 2002 WRX...
    Aug 2009
    p1086
    hey thanks ,just are u able to give me a quick idea where its is located ..will be great thanks again
    DUB
    DUB is offline
    Registered User DUB's Avatar
    Jul 2007
    SLT, CA
    Aug 2009
    p1086
    thanks bro .. great
    Feb 2010
    spring hill fl
    this is great
    You guys are great with out this post I would have just replaced everything.
    Subaru does not sell this part by it's self (t.g.v sensor)
    thanks again.
    Registered User gogocricket's Avatar
    Jun 2011
    Grand Rapids, Michigan, United States
    I also have a P1086. Also tried clearing it, to no avail. I read the thread on scooby mods; http://www.scoobymods.com/tgv-sensor...086-t5160.html
    I see that the description for code P1086 says "Tumble Generated Valve Position Sensor 2 Circuit Low"
    Where is sensor 2 located, by the turbo or the intake manifold?
    Does anyone know what a 'circuit low' code means as opposed to 'circuit high,' P1087? Does it make a difference regarding what needs to be done to fix the problem?
