wastegate issuse
Results 1 to 4 of 4
This is a discussion on wastegate issuse within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; when i am accelerating through 3rd gear, at about 4-5k rpms, i hear a pop and a sudden jerk. my ...
    Registered User ohsixwgnz's Avatar
    May 2007
    Radford, VA
    wastegate issuse
    when i am accelerating through 3rd gear, at about 4-5k rpms, i hear a pop and a sudden jerk. my check engine light comes on and my cruise control light blinks. i took it to advacned and their computer says that Solenoid A in my wastegate disengaged or something along those lines after a couple days the engine light turns off. i have a short ram intake on the car, could the problem be just too much air flow that the stock wastegate can't handle and it is tripping itself? or something else, i have other after market parts on the car so subaru won't look at it unless it is back to stock specs...would maybe a BOV fix this issue?
    Jun 2007
    Great Salt City of Utah
    Quote Originally Posted by ohsixwgnz View Post
    List all of your mods compleatly. Sounds like a fuel cut from over boosting. Do you have any sort of boost control. Have you messed with any of the boost lines.
    May 2007
    Radford, VA
    just intake and exhaust now, was running stage 2 with cobb AP but it is back to stock because i had to replace the clutch about a month ago. other than that, unless some of the subaru guys tampered with stuff nothing else has been changed
    Oct 2007
    Hoodbridge, VA
    No, no, no. A BOV will make it worse.
    Definitely sounds like boost cut. I hope you have a 02-03. otherwise a tune or put your stock intake box back on right now.
    Has it done it since?
    Was it cold out?
    If your CEL and Cruise flashed that = very bad. Probably boost cut or a violent knock or det.
    No the stock wastegate works the opposite way. If there was something wrong you would only have 7-9 psi.
    The definite fix GET A PROTUNE !
