weird vibration at idle
Results 1 to 7 of 7
This is a discussion on weird vibration at idle within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 2005 wrx and recently i my car has been acting really odd. I was sitting in the ...
    Dec 2006
    Reno Nevada
    I have a 2005 wrx and recently i my car has been acting really odd. I was sitting in the parking lot at work and the car started vibrating a ton. Like enough to where my hood scoop was actually shaking. when i revved it went a way. when i was driving home every stop light i got to it just kept vibrating violently. the only thing on my car right now is intake due to me getting a turbo swap and tune on friday. anyone else have this problem? (oh and yes i know my grammar sucks right now...im very tired)
    Boba Fett BrianH's Avatar
    Oct 2003
    Way up high.
    could be as simple as a vac. leak causing idle problems.
    Jul 2007
    Not sure about the WRX, but a friend had a similar problem with his Infiniti. Whenever he stopped the car would shake and I mean shake BAD, so bad that you had to use your oh **** handle just to stay in your seat. It ended up being something with his fuel pump, car wasn't getting any/enough gas and was trying to stall every time he stopped.
    Not sure though, there are a ton of different shakes/vibrations that can be caused by a lot of things and it's a bit tough to tell unless you can sit in the car and feel it for yourself. His sounded similar though, shaking violently as you put it, plus his also went away when he revved it a bit.
    Sorry, can't help ya much more than that
    Registered User ZxZDeViLZxZ's Avatar
    Sep 2007
    hmmz i have a 03 wrx wagon and it makes odd vibrations at idle sometimes aswell feels like you car is rocking side to side however it only does it sometimes and the rpms are never high when doing so.... i took mine in and had them look it over my maf was dirty cleaned it and that was their fix for it however it still does it from time to time
    Registered User WRX7886's Avatar
    Oct 2007
    im on my second subaru right now and my last one was also an impreza and ive also experienced the car shaking a little. i heard it was normal for boxer engines or maybe its just normal for subaru boxer engines. theres def. something wrong though if yours is shaking that much. it sounds like it may be a vacuum leak or maybe your idle control needs adjusting or your maf sensor needs to be cleaned. i have the some problem but mine only does it when the cooling fans come on so thats what people told me could be wrong. also what grade gas do you use? i heard after using low grade gas for an extended period of time will cause your car to run rough.
    DUB
    DUB is offline
    Registered User DUB's Avatar
    Jul 2007
    SLT, CA
    OP: Do you have a CEL?
    Dec 2006
    Reno Nevada
    Yeah it was the maf. Thanks everyone
