friend having a problem, please help
Results 1 to 5 of 5
This is a discussion on friend having a problem, please help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Alright, i Tried to do a search, but i couldn't find anyone who had the same problem as I do. ...
    NMZ
    NMZ is offline
    Registered User NMZ's Avatar
    Oct 2007
    the rear of my car makes a loud WHIRRRRRR noise when im decellerating or putting pressure on the rear (in gear or out of gear, but usually in neutral). It only does it after the car is warmed up and driven for about 20 minutes. It goes away if i tap on the brake. Sounds like chewbaca, sorta.
    At first I thought it was the wheel bearings, but I got those changed out and it's still making the noise, then i thought it was the brake shoes, but those seem fine.
    Any thoughts? Thanks!
    Mods are:
    KB SS and Bushings
    Exedy OEM Replacement
    O yea, and this is for a 04 WRX
    Registered User HxcJohnny's Avatar
    May 2007
    Statesville, NC
    you have rear shoes?
    NMZ
    NMZ is offline
    Oct 2007
    Quote Originally Posted by HxcJohnny View Post
    no
    NY
    that chick is sssssexy
    Registered User BlazeYellowWRX's Avatar
    Oct 2007
    Fishers, IN
    Have you checked the transmission fluid level?
