noob ?
Results 1 to 7 of 7
This is a discussion on noob ? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; where can i find a DIY on brake pads on my 04 sti?...
    Jul 2007
    noob ?
    They're a lot like any other brake setup but they have pins to deal with. You'll probably need something to push the pins in with. Other than that, straightforward. See here:
    http://forums.nasioc.com/forums/show...ace+brake+pads
    Les jeux sont faits.
    Jan 2007
    Dirtee Jersee
    Remove wheel.
    Look at caliper. There's two bolts holding it down. Loosen one, then the other, then take them both out.
    Slide caliper off.
    Take pads out
    There's a metal backing that goes on the pads. Take that off your old pads. Put on new pads.
    Insert pads.
    The caliper pistons will be extended, how far depends on how worn your old pads were. You gotta push those back in. Don't hurt the pistons. It might take a wee bit of force but you can push them in with your fingers.
    Slide caliper back on.
    Put wheel back on.
    Drive around and break in the brakes. You'll smell a stinky burning smell. That's normal.
  5. #4
    The Brembo units use cotter pins to locate cylindrical rods with holes in them. The caliper does not need to be removed. Once the pins are removed and the pads are "unstuck" it's downhill.
  6. #5
    Jan 2007
    Dirtee Jersee
    oh you've got an STi. for some reason i missed that important detail.
    lol
  7. #6
    Registered User independent 68's Avatar
    Jul 2007
    Parker, Co
    Quote Originally Posted by Blup View Post
    lol
    nice lol
    "Whatever it takes"
  8. #7
    Apr 2004
    Southeastern PA
    http://www.scoobymods.com/index.php
    Moving to General Maintenance, Troubleshooting & Tutorials ...
    Mods & Pics
