Dimming dash light problem
Results 1 to 7 of 7
This is a discussion on Dimming dash light problem within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So I first noticed my dash illumination lights as well as the illumination lights for the radio and dash where ...
    Registered User TheMainFrame's Avatar
    Dec 2005
    Houston, TX
    So I first noticed my dash illumination lights as well as the illumination lights for the radio and dash where out so i replaced the #12 fuse and it did the trick... lasted 2 days and they where out again...
    Replaced it again and it only lasted one trip.. and l couldent find the problem nore the time to look into it further so for like a week ive been poping a new fuse in every trip that requires night illumination...
    just the other day i noticed that the fuses blew almost immediatly and so did a 20A (it takes a 10A regulary)
    Now even with a perfectly good 20A fuse (im outta 10A and using 20A just for troubleshooting the problem, ill grab some 10's in the morning) in the socket there is no lights!
    Where should i check? any diagrams available for this? perhaps a common problem?
    I could use any help at all really!
    Bugeye Mafia #125 - And Proud Of It!
    Nov 2005
    Central Florida
    check all wires for a short
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Dec 2005
    Houston, TX
    Quote Originally Posted by rr1911 View Post
    Are there diagrams available somewhere.. id imagine since there seems to be no power at all and the fuses arent being blown anymore.. but the illumination lights for dash, radio, and nobs all arent working then I can save some time by starting where all the lines come together as one...
    that is if i explained that well enough
    Dec 2005
    Houston, TX
    And can i visual tell if a wire is shorted out?
    Jan 2009
    North Platte NE
    same problem
    ya i have a 06 wrx and am having the same problems that you are with the dash dimmer lights did you ever figure anything out or find out how to tell if a wire has a short any info would be great thanks
    Registered User FORESTERSTI's Avatar
    Feb 2010
    chile
    hello, did you solved the issue?? my 2000 forester sti burns the number 12 fuse all the time
    Jan 2009
    North Platte NE
    update
    so i finely figured out that It was the Integrated Unit. I pulled it out from under drivers side dash, yanked out the ckt board and found a spot on the board that looked fried. I soldered in a jumper and put it all back together and whoalla! Dashlight
    Guy over on nosioc had the same problem thanks to him
