Tumble Generator???
Results 1 to 10 of 10
This is a discussion on Tumble Generator??? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Got code 1088 and 1090. P1090 Tumble generator valve #1 (RH) malfunction (stuck open) and P1088 Tumble generator valve #1 ...
    Aug 2006
    Tumble Generator???
    Got code 1088 and 1090. P1090 Tumble generator valve #1 (RH) malfunction (stuck open) and P1088 Tumble generator valve #1 (RH) position sensor circuit low input. Any ideas on what's going on or how I can fix that. Or if it's a major problem. Got 03 Impreza WRX. It drives the same when I first got it. Just wondering what I need to do. Thanks for any help.
    - Al Stewart
    Aug 2006
    d
    Those Threads help but the only problem I have is that I don't even know what the Tumble Generator is, where it's located, or what it looks like. It kicked on completely after I put an STI exhaust on the car. I haven't messed with under the hood at all. From what the guys are talking on the Nasi forums it's an easy fix. Lemme know guys.
    Jun 2007
    Great Salt City of Utah
    Quote Originally Posted by zerowrx View Post
    +1 What is a tumble generator
    Aug 2006
    a
    Hahaha!! You got me. I'm looking at an 04 STI service manual. And it identifies what the Tumble Generator Valve Assembly looks like and where it is located. Will this be about the same for my 03 Subaru WRX. Same torque specs and such?
    Boba Fett BrianH's Avatar
    Oct 2003
    Way up high.
    It's an extension of the intake manifold which goes into the heads on your car. . . the piece that your injectors go into. I would start by looking for loose wiring, it could just be an unplugged motor.
    Are you the first owner of your WRX?
    Aug 2006
    a
    I do believe the second owner. Car has been modified before I got it. I'm going to look at the wiring and such going to it. It just sorta randomly happened one day with the check engine light. It'd go off and come back one occasionally but it finally came on for good.
    Oct 2003
    Way up high.
    A good pictures of of APS' website where you can see the STi intake manifold with the TGV's bolted to it. On the lower right hand side of the screen you can see an unplugged sensor right above the word intake. I can't remember if there are four motors or just two but you need to locate those and verify they are plugged in on your car. it is possibl that one of them is stuck or has died.
    From what you've written it's likely someone sometime knocked something loose. If it were a single CEL I'd be more suspicious of a failure, but since you're getting two fault codes I'd look for bad workmanship before anything else.
    - Al Stewart
    Brooklyn, NY
    bored at work and i figured i'd give my 2 cents. from what i remember from reading the service manual. tumble gererators are a couple sticks that swirl the air for better low end torque. the units are located between the manifold and the head. from what i remember the diagram. its controlled via vacuum / boost not sure how it works. but a solinoid will open letting vacuum / boost move a plunger type motor. so check for vacuum hoses loose. also there is a sensor that checks to see the position of the tumble generator. make sure that everything is connected.. let us know... whats up.
    - one word; Thunder cougar falcon bird.
