BLI Issue
Results 1 to 7 of 7
This is a discussion on BLI Issue within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi Guys, Hopefully someone can point me to the right direction...I've only had my 02 WRX Sedan for a few ...
    May 2007
    Philly
    BLI Issue
    Hi Guys,
    Hopefully someone can point me to the right direction...I've only had my 02 WRX Sedan for a few months now and I've been happy with it...until this morning . My "BRAKE" light indicator won't go off (yes I released the parking brake). The "BRAKE" light will remain on for the entire drive and will "intermittently" go off and then come back on.
    Any ideas what this means? What should I check out? What can it be?
    TIA
    Registered User SubyPsycho's Avatar
    PA
    The parking brake is basically a drum brake inside the rear rotors. If the light is occassionally going off, I bet that a spring in the parking brake assembly broke or came loose, which is causing something to be slightly out of place and trip the parking brake sensor. I would remove the rear rotors and check for any broken or unattached springs first.
    Jun 2007
    Great Salt City of Utah
    You could try and loosen the set screw located at the parking brake handle. I would try that before tearing into the rear rotor.
    Feb 2003
    Nope, I bet you're low on brake fluid! Just fill it up and you'll be OK
    May 2007
    Philly
    Quote Originally Posted by evilenv View Post
    you were right. i checked the brake fluid and it was a little on the low side. it would go off in the morning (cooler outside) and on the drive home from work (warmer) it would never go off. i filled it up to the max line and it hasn't come back since.
    but now i'm thinking i have a possible slow leak in the brake lines?
    Oct 2005
    Late Devonian
    Quote Originally Posted by wrxnoobie02 View Post
    By all means then get under your car and have a look. Brake leaks are obvious. It is probably just that your brake pads are now thinner, so more fluid is in the caliper itself instead of in the reservoir. This is totally normal but look anyways.
    Feb 2003
    definetly check for a leak, but I don't think you'll find one
    as your brake pads wear the pistons in the calipers extend more, thus they contain more of the brake fluid which is why you were low....check your pads as you are probably close to needing new ones (most likely fronts)....you will need to remove a small amount of fluid from the master cylinder resevoir when you compress the calipers for the new pads to fit
