Air Conditioning Problems
Results 1 to 15 of 19
This is a discussion on Air Conditioning Problems within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So the other day I was blasting the AC, everything going fine. I park the car for an hour, i ...
    Oct 2004
    Westchester Cnty, NY
    So the other day I was blasting the AC, everything going fine. I park the car for an hour, i get back in turn the car over and the AC wont work.
    When I hit the button it doesnt click or anything. Any ideas? Compressor dead? Leak? Need a recharge?
    2015 Plasma Green Pearl XV Crosstrek Hybrid Touring
    2011 Lightning Red WRX LTD Sedan w/ Nav (returned)
    2008 Lightning Red WRX Prem. Hatch w/ Nav (returned)
    2005 San Remo Red WRX Prem. Sedan w/ VF34 (traded)
    Administrator
    May 2003
    1: Check and see if the compressor spins.
    2: Check for freon.
    3: If there isn't any freon, find the leak, fix the leak, and recharge.
    4: If the compressor siezed, replace the compressor and recharge.
    5: If the compressor is functioning, and the freon is full, check switches and/or temp control.
    Oct 2004
    The compressor was not spinning...
    I picked up a recharge kit and filled her up. Compressor spins and AC worked properly.
    HOWEVER, after 1 hour of driving with the AC on it no longer works and I can hear a high pitched noise (air flow) like when I first lost the AC.
    I guess I have a leak. Ugh.
    GraysonSubaru's Avatar
    May 2005
    Knoxville, TN
    i had to replace the compressor in my 2003. the A/C worked ok, but was starting to make a belt squeal type noise every once in awhile. i thought the belt was loose or needed replaced. after further inspection, we found it was the compressor going bad. replaced it with a used one for $100 with a year warranty, recharged and it worked fine.
    Hey, being the forum car ADD guy is better than being the forum OG.
    Well nobody cares what you think, Seth
    Oct 2004
    Quote Originally Posted by GraysonSubaru View Post
    I dont get any noises like that. I really think it must be a leak since after an hour the AC stopped working. ugh. must be a small leak.
    Luckily its in the 60's and 70's this week. Hopefully it stays like that till October and gets cold. I dont feel like spending $300 to get this fixed a Subaru.
    Get your self some a/c diy and put in the system. Then run it and look at all yout a/c lines with a blacklight. THe dye will show up in the light and you have found your leak.
    Registered User 07STi8U's Avatar
    Jun 2007
    Seven Valleys, PA
    Leaking A/C
    +1
    Oct 2004
    Quote Originally Posted by juicedz View Post
    My kit didnt come w/ the dye. But even if i found it i would have to replace the piping...not sure if thats worth it for a month or less of AC driving.
    Registered User Ice02WRX's Avatar
    Jessup, MD
    Sounds like 4 doors = 4 windows coming down.
    Quote Originally Posted by D0WNxSH1FT View Post
    It might be worth it for that 1 month AC plus 6 or so defogging, depends.
    Oct 2004
    Defogging, hahah, I live in the Northeast. It will be under 50 degrees and maybe snowing in a month or so.
    Aha, I see.
    Oct 2004
    Aha, I see.
    I wish i lived in SoCal. So nice, warm, sunny and then you can just drive to go skiing if you want.
    The grass is always greener on the other side as they say... It has its ups and downs over here too. 47C the other day. The sun can melt metal sometimes down here...
    Registered User krakkaplease's Avatar
    Jan 2007
    az
    um i would suggest fixing it. if there is a refrigerant leak and you have no refrigerant in the system you are letting moisture and "contaminates" into your a/c system. to get rid of the contaminates you have to change out the refrigerant oil. if you dont you will be buying a compressor... and if you heard it hissing it probably isnt a small leak...
    good luck.
