Hesitation?
Results 1 to 7 of 7
This is a discussion on Hesitation? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Help, I have a 02 WRX with an APS 35 turbo, bigger top-mount intercooler, new engine in December, mostly stock ...
    Feb 2003
    Hesitation?
    Help,
    I have a 02 WRX with an APS 35 turbo, bigger top-mount intercooler, new engine in December, mostly stock stuff....
    The car is slow at low RPMs (slower than usual), its normal at mid and high end.....also I noticed some smoke coming out of the engine when the blow off valve releases.....sometimes it smells really bad like gas, but that might not be related? Also, at idle the engine shakes back and forth enough to make the car wiggle........
    thanks in advance
    Mar 2007
    delaware
    Quote Originally Posted by evilenv View Post
    Help,
    thanks in advance
    bigger turbo bigger lag..you might wanna get new engine and tranny mount, one of my friend messed up his tranny cuz of all the vibration(i think his dp was hitting the tranny), he had ****loads of stuffs done to it too. smoke might be from heat wrap if you have one for the dp, and catless make it smell more like gas, lastly for the ideal issue adjust you BOV
    Registered User ryanwrxduksa's Avatar
    Jun 2006
    NW ct
    any cels? the lack of power would probally be from the larger turbo... what are you running for engine manegement?
    07 white STi in CT
    Feb 2003
    no CEL...I bought the car already modded and I've had it over 2 and a half years and it's always had this turbo and it's more than just lag, it's something else....it's really slow off the line, worse than a hyundai
    I will check the engine and tranny mounts...the downpipe does touch the transmission a little bit, but no heat wrap
    I've checked the fuel pressure and it's within specs, I think I'm going to check for any air leaks and also pull my plugs to see if there's anything else unusual.....if you guys have any other suggestions it could be helpful
    Mar 2007
    delaware
    definitely check the spark plugs and coils, my next guess would be injectors and fuel pump maybe fuel filter
    Nov 2005
    Central Florida
    i say u need a retune
    also the hot summer equals more heat soak wich equals less power
    with the aps35 u should have a fmic imo
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Feb 2003
    Thanks everyone....I'll keep this updated with what I find.....I know it's hot, but the car has lost more power than that, it's obvious when I drive
    the factory service manual lists the fuel pump as a possible cause for the smell also.....pressure tested good, but it might be intermitent
    a FMIC would be nice, but I dont want to cut my bumper out....the wife has to drive this car, hehe
