Throw out bearing and clutch....?
Results 1 to 5 of 5
This is a discussion on Throw out bearing and clutch....? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just picked up an 02 wrx 2 weeks ago, and when I got it I noticed a slight chatter ...
    Registered User JSarv's Avatar
    May 2007
    Illinois
    I just picked up an 02 wrx 2 weeks ago, and when I got it I noticed a slight chatter in the clutch. It has gotten a little worse but not enough to really care. Anyway it only chatters when its cold. And I'm hearing a noise, I presume its the throw out bearing due to, when i push the clutch in it slowly goes away. sounds like a throw out bearing to me anyway, just seem awfully loud and seems like it takes a little long to go away after the clutch is depressed?!?!
    any ideas? maybe the trans? could it be an aftermarket clutch? seems like once its warm its either on or off.
    A 50 year old guy owned it before me and everything looks to be as if it has not been tampered with.
    any ideas? i can get a sound clip if it would make it easier?!
    thanks
    Jerod
    May 2007
    Illinois
    bump just because no one cares?
    Mar 2003
    tacoma
    not sure about the chatter but the noise, do you hear it in neutral, 1/2nd gear at really low speeds without touching the clutch, then as soon as you put pressure on the clutch pedal the noise goes away? If so 90% chance its your throwout bearing.
    May 2007
    Illinois
    Not sure about 1/2 gear but in neutral. I'm 77.5944% sure its the throw out bearing, however, NORMAL noise from a throw out bearing goes away almost instantly when the clutch is depressed, this noise has a tick to it as well (almost identical to injector tick) and a woosh. Anyway it all goes away when the clutch is depressed but it just seems to take longer than any other car with a bad throw out bearing.
    don't know? kind of confused actually!
    thanks for replying btw!!
    Jerod
    May 2007
    Illinois
    bump... because I can
