missfire and compression way off.
Results 1 to 7 of 7
This is a discussion on missfire and compression way off. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi,i have a 2001 wrx that is a little poorly.To give a little background the car has a stage one ...
    nottingham
    Hi,i have a 2001 wrx that is a little poorly.To give a little background the car has a stage one upgrade to 285 bhp by means of the following;
    straight through 3inch exhaust,
    255 fuel pump,
    boost controller,(set at one bar)
    APS air filter,
    APS intercooler piping,
    UNI CHIP piggy back ecu,
    The car has been running very well for about three years,(since upgrade) but now keeps throwing up cel 304 (missfire on cyl 4 ).It was starting to be hesitent and a little rough.I have not noticed any major power loss although when running rough its hard to tell.It has since been to a garage to diagnose the problem and after a morning and a 170 pounds later they have told me that after a compression test things are not good.! The test results were cyl 1 & 3 @ 155 & 158 and 2 & 4 were 100 & 85 The garage said this is not good and they should all be roughly the same .They now say they will check timing but i dont know if thats right or not. HELP.
    Any of you techs out there with any ideas,either on possible causes and or what to do next please feel free to reply.Thanks.
    Registered User WRX13oy's Avatar
    Jul 2003
    SOCAL!! 91752
    thats not good. my old engine, cylinder 4 was really low compared to the other cylinders. a few weeks later, bye bye engine. could be that you have a bad piston ring or something
    SOCAL F4#02 OG member
    2002 PSM WRX stage 6
    2007 Kawasaki Ninja ZX6R
    Registered User ScoobVee's Avatar
    Mar 2004
    IBdeadheadgasket
    Edit: a second opinion never really hurts
    - Local Riceist
    Registered User ryanwrxduksa's Avatar
    Jun 2006
    NW ct
    timing belt is supposed to be done at 105k. hopefully it was done...
    07 white STi in CT
    Moderator
    Apr 2002
    Greenville, SC
    I'll tenatively concur with the head gasket guess. That'll be spendy, if that's the case, especially with a shop that's charging £170 just to check your compression.
    I assume you don't have the tools/knowhow to do any work yourself? Normally I'd recommend tearing it down to the timing belt to take a quick peek, make sure you didn't somehow jump a tooth. But that would take about twice as long as checking compression, so I'd hate to think what you'd spend to have that done.
    Er, well, then again... they've got to do that much to replace the head gasket. So maybe they could get that far, and if the timing is okay, they could keep going.
    Good luck, man.
    2002 WRX Sedan - 2000 Mazda Miata
    Do us all a favor: work on learning how to drive your car before adding more power. Pretty please.
    nottingham
    Cheers for reply autoXjunkie.I do have some know how but my joinery business isnt allowing the time and i am not sure i could go to the lengths of a full rebuild.!!The most i have managed is a clutch on an opel manta which involves drive shaft and geerbox removal.Any way i have got to wait til tuesday to have any idea how screwed rex is.!Will update then and thanks for everyones responses.
    nottingham
    compression way off equals piston cracked
    Hi, just updating for those who are interested .My last post was headed missfire and compression way off.I have since had the engine stripped down and found two cracked pistons which is not good.They say my uni chip is the problem and it was down to this that damaged the pistons , maybe due to detonation .I am having forged pistons put back in and putting the uni chip in the sh***er.I will then have it remapped using ecutek as this will retain my knock sensor and be alot more reliable.Now all i have to do is wait for my scooby to be brought back to and beyond its former glory , oh yes and pay the 2.5k its going to cost.
